 H4 Head light Bulb Question
I did not feel any heat at all , just a little warm after installing the Native H4 , I have to say that I never checked the heat when running the standard H4 , could even be the same warmth.
(12-27-2018, 01:38 AM)Houtman_imp Wrote: I did not feel any heat at all , just a little warm after installing the Native H4 , I have to say that I never checked the heat when running the standard H4 , could even be the same warmth.
Thanks Houtman. That is encouraging, given even the large heatsink on some LED subassemblies.
I would expect [good] engineers to do proper heat management design considerations in an enclosed environment. That said, some do not and we pay in inconvenience.
There are many types of LED H4 replacements bulbs for sale but I think that you are safe with the Native H4 one as many bikers have installed them on their bikes and many of the other ones for sale seem more for car/truck applications , see the reviews on the ADVMONSTER website as well.
Thumbs Up Tanks.
So do we have a definitive review of the Native H4's performance compared to the OEM bulb? My main focus is on being able to see at night and low-beam/high beam distance and brightness. I find it way too easy to outrun the stock headlight. And does it work well with the standard "reflector" setup? Sorry, I know that isn't the proper term.
I have not had my bike out at night but in my garage with no lights on you can see a BIG difference , the H4R3 I put on my wife's car are MUCH better but of course on that light the dim stays on while on big beam . They are all cheap up grades , being better seen in the day time could be worth your life !
(12-26-2018, 01:34 PM)GoldOxide_imp Wrote:
(12-26-2018, 12:09 PM)Elevenminusoneblade_imp Wrote: I recently installed one of these: https://vintagecarleds.com/shop/bulbs-on...ulbs-only/ in both my Moto Guzzi and Ducati. Installation was as easy as replacing a standard halogen bulb. Super bright and not bluish at all.
I still wonder how effective cooling is when the warm air accumulates in the mostly closed plastic shell of the original CB headlamp assembly. Maybe it is a non-issue if the temperatures approach that of the halogen bulb or is less. However, the LED electronics have to still tolerate the internal headlight ambient temperature, something that is a non-issue for a halogen bulb (no electronics).
I'm not sure. The website describes a brushless fan which cools things. You wouldn't know it by looking at it though. Certainly can't hear anything. They're about twice the price of the native h4 bulbs.
(12-27-2018, 04:02 AM)Houtman_imp Wrote: I have not had my bike out at night but in my garage with no lights on you can see a BIG difference , the H4R3 I put on my wife's car are MUCH better but of course on that light the dim stays on while on big beam . They are all cheap up grades , being better seen in the day time could be worth your life !
Thanks for the response. And I'll keep you in my prayers for the surgery. Hope to see you again at the next rally.
I updated my headlight bulb using the Sylvania Silverstar Ultra 9003. Brighter white light. 20 bucks at the local auto parts store. Very happy with the performance.
I did ride last night for 3 hours in dark road canyons and free way and highways, my members of riding group were very loud complimenting the new bulb, I was also able to see much better , I used the H4 direct plug in from ADVmostre ,installation was as easy as lifting your finger, then i used the side screw to point it exactly to the 12 o'clock, and used two side screws to lift it to point to the distance good for my riding . I could not be happier with the 40 $ spent. I was thinking to ad fog lights for more visibility ,which will not be needed.
Thank you forum.
Ride safe/Ride long
   Light problems/electrical Dude_imp 6 607 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Brake reservoir screw head issue satchit 72 5,544 04-24-2022, 11:55 PM
  Chrome cylinder head cap Juancho76_imp 21 1,799 04-03-2022, 08:48 AM
Last Post: Juancho76_imp
  Cams, Compression, Head Work? boynton6spd_imp 12 1,000 08-08-2021, 02:27 AM
Last Post: old blue_imp
  CB900 Custom oil stopper on valve head AOrhun_imp 9 844 01-27-2021, 10:06 PM
  Fork Tube hex head bolt tool fitment ? bflint 8 776 11-30-2020, 06:24 PM
Last Post: jtopiso_imp
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 663 09-01-2020, 12:19 AM
  JIS Cross Head Screw Drivers 2017EX_imp 15 1,431 04-15-2020, 01:53 AM
   Engine light Blinking tory_imp 25 1,999 12-04-2019, 10:38 PM
  Replacing turn signal bulb on a 14. the Ferret 7 539 04-24-2019, 01:33 AM
Last Post: Rocky_imp
