 Engine light Blinking
What​ happen.
Engine.light Blinking​ any​one​ pls.tell.me
Thank​s
Hey, Tory, I don't have my manual handy at the moment but in automotive circles that indicates a condition that could harm the catalytic converter. Usually a misfire. If no one else chimes in I will be able to post chapter and verse later....
Ben
Hi Tory, your oxigen sensor heater is open circuit, code 23;
Have a look if the wiring is damaged on the oxigen sensor and the connector is in place.
PCM codes and their meaning
PCM DTCs:
1 - manifold absolute pressure (MAP) sensor (1-1=low voltage, 1-2=high voltage)
7 - engine coolant temperature (ECT) sensor (7-1=low voltage, 7-2=high voltage)
8 - throttle position (TP) sensor (8-1=low voltage, 8-2=high voltage)
9 - intake air temperature (IAT) sensor (9-1=low voltage, 9-2=high voltage)
11 - vehicle speed (VS) sensor (11-1=VS malfunction, intermittent connection etc)
12 - #1 (left) fuel injector (12-1=FI malfunction, intermittent connection etc)
13 - #2 (right) fuel injector (13-1=FI malfunction, intermittent connection etc)
21 - oxygen (O2) sensor (21-1=O2S malfunction, intermittent connection etc)
23 - oxygen (O2) heater (23-1=O2 heater malfunction, intermittent connection etc)
29 - IACV (idle air control valve (29-1=IACV malfunction, intermittent connection etc)
54 - BA (bank angle) sensor (54-1=low voltage, 54-2=high voltage)
86 - serial communications (PCM to cluster) (86-1=communications error, bad power to cluster)
If the bike drives normally it may be a good time to install an o2 sensor eliminator, have a look at these links;
http://cb1100forum.com/forum/showthread....eliminator
Tory Note that the eliminator will not work on 2017 models, only on earlier ones.
Personally i have installed a 330 ohm resistor and it works fine on my 2010 cb1100.
Great post Max, and saved me some work Wink I just got the manual out and then saw your post.
My prediction. He put on an aftermarket exhaust and no O2 sensor. I could be wrong...
Thank​s​ all.of.you problem​ so​love​ by​ O2cencer
Befor
After
Max, excellent/professional job!! Thumbs Up
(11-27-2019, 11:16 AM)peterbaron_imp Wrote: Max, excellent/professional job!! Thumbs Up
So 2 blinks = 2 and three blinks = 3
code is 23...cool, learned something
new about my bike today... I think in the
recesses of my mind I know blinks are
code, but I never seem to remember in the
moment and I just think “huh?, its blinking!”
Very helpful information, max, and even better now I know how you arrived at 23.
Is there a difference between 23 and 23-1. If so, how is it signalled?
Tory glad it is fixed, what was the repair? we would like to knowThumbs Up
Cormanus i was hoping houtman would chime in and cleared this up because the1 and 2 stands for two different faults.
i guess it is another short flash after the 23 code but i have not seen any example of this, i wondered the same thing.
IIRC the sub codes don’t flash. Need a code reader for those. I’ll check the manual in a while to be sure. Its too early now. Need coffee Wink
Photo First Check Engine Light Ever on a Bike doug1976 2 227 01-14-2026, 06:47 PM
  engine light tpo12001_imp 16 1,396 01-14-2026, 05:26 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,245 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
   Light problems/electrical Dude_imp 6 572 09-13-2023, 07:21 PM
Last Post: Dude_imp
  Oil light turn on/off with hot engine Alessandro78Rome_imp 3 427 07-03-2023, 10:18 PM
   Ticking noise from top part of engine Kingkong_imp 40 2,742 03-18-2021, 01:22 AM
  check engine light stays on, on my 2017 Houtman_imp 51 3,370 07-27-2019, 01:27 PM
Last Post: itstuantran_imp
  Location of Engine Number on Engine? cb1100_dude_imp 2 332 05-29-2019, 01:44 PM
Last Post: cb1100_dude_imp
  running light and brake light Ennsync_imp 3 422 01-02-2019, 11:24 PM
   H4 Head light Bulb Question Ennsync_imp 36 2,489 12-30-2018, 01:48 PM
