Chain Lube
But is it as good as gear oil?
But is it as cheap as gear oil ?
I'm just using a can on Honda branded chain spray. Allways assumed it was for rust prevention. And I always clean my chain at times of need. Amazing how touchy it gets when the chain isn't adjusted properly.
http://cb1100forum.com/forum/showthread....#pid210325
Post 10
OTOH I lubed (wax based spray for benefit of orings) the CBs chain every ~600 miles and no adjustment needed for the 12,500 miles I enjoyed it...that I remember.
well, don't know if this is ok to post on the oiling chain tread, but, something weird happened to my chain, with 19000 km the X rings started to break, I don't know if it was because of my bad cleaning method, my choice of cleaning product, or the different oils I used
what I know is that I killed the X rings on a DID chain with only 19000 km
More info Motorat. What is your method and product?
Not acetone and a wire wheel I hope Smile
For the CB I used Dupont Chainsaver ($7 at Walmart)
It is labeled"o-ring safe"
(07-01-2019, 03:01 AM)Lord Popgun_imp Wrote: More info Motorat. What is your method and product?
no wire wheel Undecided, I used a small paint brush Cool,
but the cleaning was done with something I thought to be petroleo, like the one used to light those old lamps, it's something I have at work, but probably is not what I thought it to bee.
not using that any more, just don't know what to use to remove the old dirt and grime out of the chain
Yeah, maybe that was it. Sounds like petroleo is what we in the US call kerosene.
(07-01-2019, 03:05 AM)SportsterDoc_imp Wrote: For the CB I used Dupont Chainsaver ($7 at Walmart)
I stocked up on the Dupont Teflon multi-purpose dry wax spray lube just before it was discontinued in favor of the Chainsaver.
I have two cans untouched and one in use so I'm going to continue with my usual routine regardless, as somebody said, even though I know now I may be wrong Big Grin Big Grin Big Grin
  Oinker Chain Lube Tool Gone in 60 4 521 01-15-2025, 08:31 PM
  Lube chain with chainsaw oil mrded_imp 43 3,122 06-01-2022, 01:20 AM
  Preferred chain lube? 2014ltdltz 19 1,509 05-23-2022, 12:17 PM
Last Post: rboe
  chain lube.. "fluid film" Chuckk_imp 14 1,024 11-19-2019, 12:57 PM
  Chain Lube Type and Frequency? Nappi185_imp 29 1,902 09-02-2017, 05:10 AM
Last Post: Nortoon_imp
  Grease Ninja - chain lube applicator Huladog_imp 14 1,012 01-05-2016, 12:39 AM
Last Post: Motogeezer1949_imp
  OEM chain Lube? Inhouse Bob 4 387 12-30-2015, 02:30 PM
Last Post: TINK_imp
  DLX chain lube technique DJS_imp 18 1,217 05-01-2015, 09:03 PM
  Chain lube frequency? Michael252_imp 41 2,747 02-13-2014, 10:52 AM
Last Post: ride4now_imp
