Dodgy Kill Switch
You may rock your switch on-off several times to get back its functionality and self contact clean out.
If problem persists, may need to take further simple action, like internal inspection/servicing/resistance measurements.....to confirm the problem and successful fixing.
I mostly use my kill switch, along with the ignition.
I waited until I got home from the rally and then tried what peterbaron suggested. After rocking it back and forth 10 or more times, it no longer is a problem.
Before I wash (power) my bike, I always wrap up switches and grip pappies with soft plastic bags that prevent any handlebar mounted switches from water intrusion = no worries later. 0.02
(09-12-2020, 07:34 AM)rickcb_imp Wrote: I waited until I got home from the rally and then tried what peterbaron suggested. After rocking it back and forth 10 or more times, it no longer is a problem.
Glad you got it sorted. I like free fixes.
Good seeing y'all again this week. Be safe and have fun! Thumbs Up
Good deal Rick!
Good job Rick, well thought out move that will help other users here and thanks for the conclusive feedback, i will use your "rock and roll" advice in the future, watch that moisture in the controlsWink
  Delay when using headlight switch? Jgarciajr40_imp 15 1,146 12-05-2022, 07:11 AM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,900 10-08-2022, 12:27 PM
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,969 07-12-2022, 08:04 PM
Last Post: tommymck
  Need a starter switch but none available Kdogg2077_imp 11 975 07-05-2021, 01:56 AM
  Turn Indicator Switch question Scotty_imp 6 517 09-22-2020, 11:58 AM
  Putting 2013 horn/turn signal switch on a 2017 pekingduck 9 652 01-02-2020, 08:37 AM
  2014 Start - Cutoff Switch Question deltamark 16 1,281 04-18-2019, 06:23 PM
Last Post: flynrider
  Horn switch position johan_imp 5 421 06-18-2018, 10:55 AM
  Front brake light switch iffy Ulvetanna_imp 0 170 06-12-2016, 10:38 AM
Last Post: Ulvetanna_imp
