Front brake light switch iffy
Noticed my FB did not actuate the light before my ride today. Obvious issue, one connector disconnected.
After checking, it came on and stayed on.
Reason is that the small screw holding the switch to the HB backed out just a tad, enough to allow the switch to move with the lever and fail to deactivate the light (remained closed).
I pulled the switch off, checked it, reinstalled with a drop of blue Loctite. Cannot tighten those too much or the switch could crack.
Another thing to look out for. Think I will order a second just in case it fails.
  Brake light jiggle Southwend 9 892 06-01-2025, 05:57 PM
Last Post: Southwend
  Front ABS Brake"Rain Stick" noise bflint 3 459 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Front brake inconsistent resistance ChiefJP_imp 16 1,368 06-14-2023, 07:46 AM
Last Post: bvictory_imp
  Sqealing front brake thop_imp 10 968 06-14-2023, 07:34 AM
  Front brake lever ROCK hard ichiban_imp 37 3,826 02-10-2023, 10:54 PM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,106 12-05-2022, 07:11 AM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,850 10-08-2022, 12:27 PM
  FRONT BRAKE TIGHTER omnimj_imp 2 265 09-08-2022, 02:43 AM
Last Post: 1985CB450_imp
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,930 07-12-2022, 08:04 PM
Last Post: tommymck
  Need a starter switch but none available Kdogg2077_imp 11 950 07-05-2021, 01:56 AM
