Air box removal
I have no idea what you are using for parts this is what I added at least the short list.
Yoshimura full exhaust
TSR Funnels
TSR Air Filter Funnel
K&N Air Filter
Secondary Air plate cut outs
I did not have any problems with the sensors or anything. It was all plug and chug. Yes I did move the air sensor over from the original exhaust to the Yoshimura one. I too had my ECU programmed by Guhl's.
When it came time to drill the 2 10mm holes, I think that was the size, just mark the spot and use a hand electric drill. I might have used a 2mm drill to pre drill the hole first. Just use easy pressure and it will go right through easy as pie. I deburred the edges with a knife when done.
When it came time to open the holes for the TSR Funnels, a few minutes with a small sanding drum on my dremel and it was done. If I remembered right you open it up to a ledge and that makes it very simple to do. Once you do the first one the rest take just minutes because you know where to stop.
This was a very easy job and just takes time. I think you are overthinking it.
Good luck let us know how you do.
(09-18-2020, 10:02 AM)teamvisegrip_imp Wrote: I have no idea what you are using for parts this is what I added at least the short list.
TSR Funnels
K&N Air Filter
Thx for your help.Stuck with air box.Can not unscrew that plastic cover at the rear fender.2 bolts at the seat lock area can’t find.
So forced the air box cover. With 7 screws.now can not screw it back.Looks like air intakes 2 big need to shave some plastic and put on silicone.
I hope you do not need to use silicone. Not the best option here. Look close at what you are doing.
Do you have the Service Manual? I think I am a pretty good mechanic but I still bought and used the manual for this job. It was very helpful.
I went through my pictures but none of them will help you. When I assembled my Airbox half to the Throttle Bodies, I put the Airbox in place over the Throttle Bodies FIRST. I THEN attached and fitted the TSR Funels after I had opened up the holes. Again when I did this I opened up the holes to a ridge and it was very easy. The Funels were a snug fit in the Airbox cover but still had enough room to allow them to be fitted after the airbox was in place on the Throttle Bodies. If you attach the Funels to the Airbox before fitting to the Throttle Bodies it will not go. Please do not use silicone. It will not go well for you.
I hope this helps.
Just installed my ECU after Guhl mode.The bike runs perfect!Highly recommended!I want to say thank u to Guhl and our lads for help and tips.God bless u and ur families!
  Valve Adjustment and Camshaft Removal dave 5 642 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 2,231 07-09-2025, 03:37 PM
Last Post: bflint
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 6,443 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 625 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Fuel Tank Removal Gabby_imp 11 996 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 327 10-11-2019, 10:59 PM
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 880 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  tire removal jdgrego1_imp 27 1,774 11-15-2018, 07:18 AM
Last Post: jdgrego1_imp
  Heated grips removal Chris potato_imp 7 484 07-26-2018, 11:27 PM
Last Post: itstuantran_imp
  Charcoal canister removal Siggy Javotnik_imp 21 1,350 07-09-2018, 10:22 AM
