Help - Overfilled Oil, how to remove?
(08-02-2022, 05:18 PM)jtopiso_imp Wrote:
(08-02-2022, 03:34 PM)ChiefJP_imp Wrote: Just did my first oil and filter change.
Used only 4 quarts (not even 4.1 like the owner's manual states) and it's completely filling the sight glass with oil. Seems super odd. Should be perfect or even a bit low. I'm wondering if the type of filter has anything to do with it. I used K&N.
Anyway, I'm going to loosen the drain plug and drain a bit of oil out. But I think on my DLX the amount to correctly fill is actually 3.9 qts. And I think someone even stated that in a comment.
Is that with a new filter? Perhaps you need to crank the engine, so some oil goes into the filter.
I actually prefilled the filter quite a bit. And sight glass is still showing full after a good 40 min ride. 4 qts is all I opened and used. My guess is it's .1 qt over filled for whatever reason. Lesson learned for next time.
Simply carefully remove the drain bolt and drain some oil. It's going to be messy. DON'T do it with HOT oil.
(09-09-2018, 12:55 PM)m in sc_imp Wrote: syringe, fork oil type. much less messy. .02
nothing reaches the oil pan from the inlet cap.:eh:
(09-09-2018, 12:45 PM)Jim21680_imp Wrote: No problem re-using the crush washer. Some people don't ever replace them.
Also, unless you REALLY overfilled it (like, and extra quart by mistake), I'd just let it be. Many new bikes, including mine, were overfilled from the factory, and it functions just fine. Save yourself the mess.
Of course it works, but if the oil seals give out ahead of time, don't complain.Smile
Too much oil strains the oil seals and is not good.
All manuals state not to exceed the quantity described.:pollice su:
I took a turkey baster from my wife's tool drawer and attached with duct tape a foot or so (.333333 meters) of rubber tubing of about the right diameter. Wiggled it down the filler hole and sucked the extra out. Worked like a charm and wasn't messy at all. My wife might dispute that, though.
Angel
(08-18-2022, 05:50 AM)Inhouse Bob_imp Wrote: I took a turkey baster from my wife's tool drawer and attached with duct tape a foot or so (.333333 meters) of rubber tubing of about the right diameter. Wiggled it down the filler hole and sucked the extra out. Worked like a charm and wasn't messy at all. My wife might dispute that, though.
Angel
How did the turkey taste? Tongue
Haahaajajah!!
  How to remove O2 sensor CB1100AZ_imp 10 928 12-13-2024, 09:57 AM
Last Post: inditx_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,419 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,470 05-10-2022, 11:12 PM
Last Post: Tom_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,363 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  How to remove turn signal bracket on 2013 model Mtnduc_imp 6 479 10-16-2019, 08:12 AM
  Overfilled oil from dealer Spiderwatts_imp 11 1,208 10-13-2017, 03:17 AM
Last Post: nhawk7504_imp
  Tank, raise or remove? MM300_imp 6 426 06-23-2017, 09:55 PM
Last Post: MM300_imp
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 350 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  How to remove bar ends twiin640_imp 4 389 02-23-2015, 07:18 AM
  Remove Seat from 2013 CB11 huxley_imp 9 710 08-19-2014, 01:22 PM
Last Post: gossman_imp
