How to remove bar ends
So normally when I need to do any kind of work to just about anything I go to the net and do a search. I've been criticized at times for the amount of research I do on some subjects. With that said I've searched a bunch on this forum and found info but for some reason I'm not understanding how it's done. Obviously I've missed something.
How do you remove the bar ends from the 1100? I have a stock '13 1100. Any info with pics is greatly appreciated. Thanks in advance.
Just the bar ends? Hold bar end. Insert allen wrench (5MM I think) and unscrew the screw. End comes right off.
To get the internal weight out, see this: [url=http://cb1100forum.com/forum/showthread.php?tid=2104&page=2]http://cb1100forum.com/forum/showthread....104&page=2
Maybe read the whole thread.
Good luck! Smile
That's what I was looking for, thanks. Wish I'd found that thread first.
(02-23-2015, 04:28 AM)twiin640_imp Wrote: So normally when I need to do any kind of work to just about anything I go to the net and do a search. I've been criticized at times for the amount of research I do on some subjects. With that said I've searched a bunch on this forum and found info but for some reason I'm not understanding how it's done. Obviously I've missed something.
Twin,
Everything you need to know along with pictures and "how to" is contained here.
http://cb1100forum.com/forum/showthread....irrors+Mod
Cheers,
Chip
Ahhh,
Thanks Chip. I didn't see that one.
  How to remove O2 sensor CB1100AZ_imp 10 874 12-13-2024, 09:57 AM
Last Post: inditx_imp
  Help - Overfilled Oil, how to remove? saru2011_imp 25 1,800 08-18-2022, 08:31 AM
Last Post: ymtnpoah11_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,362 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,399 05-10-2022, 11:12 PM
Last Post: Tom_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,288 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  How to remove turn signal bracket on 2013 model Mtnduc_imp 6 454 10-16-2019, 08:12 AM
  Tank, raise or remove? MM300_imp 6 411 06-23-2017, 09:55 PM
Last Post: MM300_imp
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 340 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  Bar. Ends Obleo 2 243 01-04-2016, 11:54 PM
Last Post: Toddman_imp
  Swapping front ends? and Exhaust? cbf1000 to cb1100 ColinSiR_imp 8 631 04-03-2015, 03:38 PM
Last Post: Elipten_imp
