 Oil Filter Options
Looks like the Bosch 3300 does NOT fit the CB1100 after all.
The threads on the Bosch are significantly closer to the mounting point on the bike, which would explain the reports of leaks when using the Bosch 3300 on a CB1100.
Apparently the Bosch 3300 used to fit, but received a design "update" that makes them unusable for Honda motorcycles.
Pic included for reference. The threaded portion of the Bosch 3300 is a full 5 mm closer to the gasket, which interferes with the gasket seating correctly on a CB1100.
Hope this saves someone else the hassle. Fortunately I can use the Bosch 3300 in my car.
Repeat...
The Bosch 3300 does NOT fit the CB1100, and should be removed from the list of equivalent oil filters.
(04-16-2021, 05:06 AM)2017EX_imp Wrote: I only use OEM Honda oil filters ( part number 15410-MFJ-D01 ) and full synthetic Honda HP4S oil. Everyone is entitled to use whatever they want in their own bikes, but my philosophy is why would I want to stray away from using oil and filters other than what Honda calls for in an expensive engine? Now, provided it is the correct type and viscosity, going with a different brand oil like Mobil 1 is no big deal. But to me the filter is a whole different ball game, case in point being K&N filter failures, among others.
Apparently there is now a new part number for the stock Honda oil filter, 15410-MFJ-D01, which is 15410-MFJ-D02. The D01 original filter is/was made by Roki, whereas the D02 is made by Wako. Other than manufacturer I have not been able to find anything about any other difference between the two. Here is a page from Babbits showing the new part number for the oil filter ( #10 of the parts listed ): https://www.babbittsonline.com/oemparts/...n-oil-pump
There are numerous listings online, including Amazon and eBay for these filters at less than $20 each, just search with the part numbers. That said, check out the attached link showing how to spot counterfeits of these oil filters first.
https://www.1000rr.net/threads/genuine-v...rs.260341/
Also included in this link, below the real vs counterfeit Honda filter video, is a video comparing actual performance of a real vs counterfeit Toyota oil filter that is interesting. Name brand cross over filters might be OK ( I personally would still not trust K&N ) assuming that they are genuine, but for any small savings in price I am staying with OEM Honda.
Biker
I saw this post with the link about fake filters and checked my stock in the garage. If I am understanding correctly, according to this 1000rr.net thread post, the filters I have which I bought from my local Honda shop are fakes. I sent the attached pics to my trusted friend at the dealer and he said these are real. What is going on here?
[Image: 358d52f53036dbfc0203b245139f2211.jpg]
[Image: f9ed05840893a275d636fc7b25a0c3c9.jpg]
They are real
(01-29-2022, 05:56 AM)The ferret_imp Wrote: They are real
I'm confused. So this post on the 1000RR site is totally incorrect but nobody has pointed that out yet? What am I missing here?
Yes it was pointed out a long time ago on this forum. Honda updated the D01 filters to a D02 filter. The CB 1000 thread was totally wrong.
There is a multi page thread on the subject called Counterfeit Oil Filters. Im on my tablet right now or Id link to it. See post 100 in that thread.
Here: http://cb1100forum.com/forum/showthread.php?tid=16787
BTW, My local Honda dealer charged me $26 bucks for one D02 Chinese oil filter. Yes, that price includes sales tax. I could have bought one on Amazon for $17. And yes, I am still looking for a good non-Honda oil filter to use in my Honda bikes. I will probably use the White Wix filters on my white Shadow... I may go back to K&N on the Cb1100 despite their recent lug nut issue.
$26 for a Chinese oil filter is usurious.
You can generally get oem Honda oil filters online for around $10 each delivered to your door
(01-29-2022, 10:33 AM)The ferret_imp Wrote: You can generally get oem Honda oil filters online for around $10 each delivered to your door
Where? Thanks in advance!
Because it is made in China doesn't mean it is counterfeit. Our import laws require companies to indicate on the product what country it is made in. Many countries are now having their products made in China because China can do it cheaper. If you threw away everything in your house and garage that was made in China, you'd have a lot more space and probably have much smaller wardrobe as well.
  NGK spark plug options Jonnyteabag_imp 7 713 08-18-2026, 07:48 PM
Last Post: SportsterDoc
  Oil Filter dave 12 625 07-26-2026, 02:33 PM
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,210 12-23-2024, 04:47 AM
  Tire Options for our CB1100 Bike #12_imp 528 41,399 12-19-2024, 04:27 AM
Last Post: Whoops
  Pod Air Filter Traumend_imp 15 1,573 03-06-2024, 08:42 AM
  Software options? josh mcelfresh_imp 2 395 08-09-2023, 03:46 AM
Last Post: josh mcelfresh_imp
  K&N air filter fitment question nikolus_imp 28 3,915 05-20-2023, 09:26 AM
Last Post: Klamathonian_imp
  Fuel filter replacement Mafd2_imp 36 3,147 02-11-2023, 01:54 AM
  Oil filter won’t come off Jgarciajr40_imp 20 1,790 01-01-2023, 09:38 AM
  Air filter options - W/ Part #'s PowerDubs_imp 10 995 09-21-2022, 04:02 AM
