Chain and Sprocket Options?
What are the different chain options available for our Elevens?
And what about sprockets? I've got a 2014 standard with the 6 speed gear box, and it could be geared a touch faster off the line... It's pretty quick as is, but my understanding is that the 2013 was actually geared a bit quicker.
Honda only offers the front and rear sprockets in one size each - 18 tooth front, 40 tooth rear. SunStar offers several options: 16, 17, and 18 tooth front, and 39, 41, 43, and 45 tooth for the rear. So you have several options if you want a little quicker acceleration. You can go smaller on the front sprocket, or larger on the rear sprocket. I don't know if you can change your sprocket size on this bike without affecting the length of the chain or not, but going one tooth shouldn't be a problem. There may be other options (vendors) out there for non-standard size sprockets. I am sure other members will respond who have actually installed non-standard size sprockets on their bikes.
Thanks for the replies. Would either of you gentlemen be willing to school me on motorcycle chains?
I'm not really sure I understand the differences and whether one type would be better than another on the CB1100.
Thanks in advance!
I have a 2013. I got 30k miles out of the first chain and sprockets, probably could have gotten a few more miles, but I had the parts and it was a rainy day.
Replaced with stock sizes. I thought about going with steeper gearing to reduce RPM at freeway speed, but I actually don't spend all that much time on the freeway so I chose to not make it complicated. Wink
530 is the chain size, recommend you get sealed; o, x, doesn't make much difference. Get a good brand like DID or EK, stay away from no names from questionable origin. Recommend you get a flare type master, stay away from the clip style links.
Stay with steel sprocket teeth; there are a lot of good brands out there. I went with Renthal all steel front and rear.
Probably a good idea to replace the rubber bumpers inside the rear hub when you replace the sprockets. Dont know if those wear out or loose elasticity, but I felt better replacing; new ones did feel a little bit "rubberier".
Plenty of good videos on Youtube showing all the tips and tricks. Good luck.
Thanks for the replies!
So a 530 size chain with 110 links.
I found it interesting that the 2013 came with a 39" rear sprocket, but the 2014 and after came with a 40" sprocket. https://sprocketcenter.com/c-1390074-str...-2019.html
Was the gearing all that different between 2013 and the later versions?
Also, Im thinking 30k miles on the chain... Should sprockets be replaced at that time as a matter of course? Or only if they're worn or I want a different ratio?
(10-02-2023, 06:40 AM)m in sc_imp Wrote: depends how worn out they are. sometime yes, sometimes no. usually, yes, change them.
That's great! Thank you!
If you're replacing your own chain, and are using a rivet type master link, then you need to purchase a rivet installation tool. I highly recommend you watch some U-tube videos on how to replace your chain if you've never done this before. Your bike came with a rivet type master link, and you'll need special tools to remove it. I personally do not like the hand held tools that press the old pin out, and I use a small, hand held grinder that I use to grind the flared ends of the master link off, and then I use a punch to complete the job. When reinstalling your new master link there are two critical dimensions that you need to achieve: First, you need to squeeze the side plate on to the correct width. You can determine the correct width by measuring the width of the new chain link - using a caliper. Second, you must flair the rivet head to the correct diameter when you squeeze it with your installation tool. The chain manufacturer will define the correct diameter of the flared head. If you have never done this before, or if you don't have much experience working on things, then you may want to leave this job to the pros because an error can be costly, and potentially dangerous.
IIRC the rivet specs when flairing are in the service manual.
Interesting thread. I’m at 25 thousand miles on an 2013 and thinking about a new chain and sprockets for next year.
My 2020 Triumph Speedmaster chain came stock with a master link clip, just saying.
  NGK spark plug options Jonnyteabag_imp 7 704 08-18-2026, 07:48 PM
Last Post: SportsterDoc
  Tire Options for our CB1100 Bike #12_imp 528 41,266 12-19-2024, 04:27 AM
Last Post: Whoops
  Chain or sprocket problem ? The Gecko_imp 14 1,396 07-30-2024, 10:05 AM
  Software options? josh mcelfresh_imp 2 392 08-09-2023, 03:46 AM
Last Post: josh mcelfresh_imp
  Front sprocket bolt cant be moved misterprofessionality 55 5,132 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,338 11-29-2022, 07:49 AM
   Oil Filter Options Yata-Garasu_imp 78 7,669 09-28-2022, 08:03 AM
Last Post: Yata-Garasu_imp
  Air filter options - W/ Part #'s PowerDubs_imp 10 982 09-21-2022, 04:02 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,076 01-03-2022, 08:30 AM
  Tires yet again - spoked wheel options Rogerdj_imp 12 1,106 09-05-2021, 04:56 PM
Last Post: Henrik_imp
