Slight Oil Leak
No response since 2022 = Angry, so we've ditched them forever.
I wanted to give this an update. I got the gasket replaced. pulling the tank, heat plate and all of the electronics wasn't too bad. got it done in a day actually.
I wasn't able to completely pull the cover from the bike, but I fished the gasket under the cover which seemed to work pretty well. I did give the top of the gasket, o -rings and isolators a bit of o ring lube to help condition them and give them some hold when putting the cover back on.
As for the sealer, I used HondaBond 4 I read that is similar to the Threebond that is recommended. I found it to more viscous then I was hoping, I ended up using a Q Tip to dab is on in the corners of the half crescents (hopefully it was enough). While I was at it, I cleaned the frame and everything up. And replaced the fuel line clip and rubber keeper like Honda recommends. Torqued the bolts down to the recommended 7ft-lbs in 2 steps and got it all back together.
Weather has been pretty wet since so I haven't had a chance to see if it fixed the leaks and sounds better then it did but I will post back once I get the chance.
Thanks everyone for the help!
(04-22-2025, 10:15 AM)mvk24_imp Wrote: [Image: fc6078337a5ece9073f09e6dac71d8d5.jpg]
My 2013 had a small leak from the corner of the L-front valve cover, did nothing, then sold the bike.
The 2014 was dry as a bone.
My DLX had a very small weeping from that area, so I installed a perfectly matched OEM drain plug gasket under the bolt, as pictured.
Tested for 1000 miles, NO leak.
Thank you mvk24
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
  Oil Leak? bvictory_imp 0 207 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,337 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 362 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,248 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 624 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 417 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,736 02-09-2019, 12:22 AM
  Gas leak ? gaby_imp 15 1,053 04-14-2018, 09:29 AM
Last Post: Desert viper_imp
   Oil leak... Please help me.. Coldshot_imp 3 765 06-22-2016, 01:23 AM
Last Post: kmoney_imp
  Oil leak..... mattmcuomo@yahoo.com 19 1,131 05-16-2016, 07:42 AM
Last Post: Riko_imp
