Shinko 777 tires for my 2017 CB1100ex
Divide by 1.6 = 15,625.
(04-30-2019, 11:07 AM)GoldOxide_imp Wrote: Divide by 1.6 = 15,625.
thanks G.O. .. and you too cormanus ...
An online converter said 15534.3
But whats a hundred miles between friends. Wink
lol ... yeah, a closer divisor is: 1.609.
1.6 is handy for short distances. Smile
15k miles on a front tire sounds like a lot to me.. but it sounds like good news.. I will be trying the rear pr-3 first.. then if my abrasive road allows me good mileage, I will replace the front with a pr-3 also.. I still have miles to go on my front Shinko with another shinko front tire at the ready.. any thoughts on my mixing of radials ?.. that being the front shinko 777 with the rear Michelin pr-3 ..... chuckk j.
(04-30-2019, 11:28 AM)Chuckk_imp Wrote: 15k miles on a front tire sounds like a lot to me.. but it sounds like good news.. I will be trying the rear pr-3 first.. then if my abrasive road allows me good mileage, I will replace the front with a pr-3 also.. I still have miles to go on my front Shinko with another shinko front tire at the ready.. any thoughts on my mixing of radials ?.. that being the front shinko 777 with the rear Michelin pr-3 ..... chuckk j.
For what it's worth, my front PR3 also made it to 15K miles and probably had another 1K left in it.
As for mixing bias and radials, it's not recommended by any of the manufacturers. I only tried it once many moons ago on my CB750. I'm not sure if it was the radial/bias combo or the tires themselves (both sport touring types), but there was a noticeable squirreliness on hard, fast corners. It went away when I eventually changed back to bias on both tires.
I think the Shinko is a radial too, isn't it, Chuckk?
I'm sure a tyre guy would tell you not to do it, but I know other folk who might say it's a Honda, you're not on the track and if it's round and made of rubber, it will be all right.
Me? I have no idea.
(04-30-2019, 05:21 PM)Cormanus_imp Wrote: I think the Shinko is a radial too, isn't it, Chuckk?
Me? I have no idea.
yes cormanus, it is also a radial, by what I have seen on some adds for the tire.. I would imagine, it would affect handling a little.. whether many riders would notice any difference is another thing.. me included.. it may be the same thing as not using the factory recommended tire sizes.. subtle changes in performance.. hopefully, there isn't any real danger in miss matching brands........ chuckk j.
Last time I was buying tyres, I was advised not to mix a PR3 front with a Pirelli Angel GT rear, even though they're both radials, because they're made from different compounds. I really don't know. I think I'll try mixing it up next time I'm forced to change tyre brands as I honestly don't think I'm a good enough rider to notice. The only issue would be if the mixture caused some erratic and unpredictable behaviour.
As for mixing bias and radials, it's not recommended by any of the manufacturers. I only tried it once many moons ago on my CB750. I'm not sure if it was the radial/bias combo or the tires themselves (both sport touring types), but there was a noticeable squirreliness on hard, fast corners. It went away when I eventually changed back to bias on both tires. flynrider, thanks for letting me know that you also get great mileage (15k on the front).. I am sure, the shinko and the pr3's[/b] are quite differerent tires.. I have always liked to match tires, but I find I will be running the pr3 on the rear and Shinko's on the front.. at least until I use the Shinko's up.. it will be interesting ........ chuckk j..
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 910 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,186 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 891 10-09-2023, 07:51 AM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,173 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 653 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 557 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 tube type tires Mafd2_imp 4 487 02-08-2023, 01:10 PM
  2017 CB1100EX Brake Bleeding M1tch_imp 1 300 03-05-2022, 04:29 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,106 07-19-2021, 08:28 AM
  2017 CB1100EX Dart Marlin Flyscreen TXBikerGuy 4 436 07-23-2020, 11:22 AM
