Side-to-side play in throttle grip
(02-22-2014, 09:30 AM)pechorin75_imp Wrote: Good point, Ferret. I actually went out and checked my other bikes. Two had similar play in the grip that I'd never noticed before. I'm wondering why it's more obvious to me on this bike....I haven't checked this, but my theory right now is that the front tire might be over-inflated--it seemed to bounce a lot over small pavement imperfections on the ride home, and that's when I was noticing my hand (and the grip) moving back and forth.
Anyway, we'll see. In any case, I'm sure I'll get used to it.
Good info on the wiring connections...I'll put that on my to-check list. Thanks!
Check the preload setting on the front forks. If it's set too stiff, you'll feel the bumps a lot more.
Yep. thats the connection, just forward of the right air intake behind the cylinder head. Wonder if its worse in warmer places. If the pictures aren't showing, I'll repost.
(02-22-2014, 01:40 PM)Obliviontoad_imp Wrote: Yep. thats the connection, just forward of the right air intake behind the cylinder head. Wonder if its worse in warmer places. If the pictures aren't showing, I'll repost.
They showed up fine the second time , thans. I still ,couldn't find the wire. Smile
(02-22-2014, 10:46 AM)The ferret_imp Wrote: Uh my bike is no longer here to check.
Anyone? Its under the FI throttle bodies I think. A wire assy about the size of a baby finger I think, grey outer housing, 2 wires inside, pulled away from an accordion looking rubber thingy ( going from memory here). It wont hurt anything if yours is pulled away, just let water down in the outer housing if you wash the bike or get caught in rain, and no you don't have to remove anything to see it.
http://cb1100forum.com/forum/showthread.php?tid=711
Sorry if someone already posted the thread on this.
(02-22-2014, 07:52 AM)pechorin75_imp Wrote: I just picked up my new-to-me '13. Really love the bike so far--it's so smooth!
Anyway, that said, I noticed something I've never encountered on any other bike I've ridden. The right-hand (throttle) grip has "play" from side to side. I didn't measure it, but you can move the whole grip maybe 2-3mm in and out (i.e., away/toward the center of the bike).
I found this a bit odd, and not really to my liking. Has anyone else noticed this, and if so, is there a fix for it? Ran some searches on the forum and have only found references to normal (radial) throttle play.
If that play still bothers you, you can always get a washer from a hardware store with a wide enough inner diameter to slip over the bar. Or if it's really 3mm, you can even get a keyring from a key maker or hardware store--they usually have a variety of sizes, and one should fit perfectly around your handlebar between the throttle housing and plastic twist-grip tube. You'll still want to have a little bit of play and use dry powdered graphite as a lubricant. Using grease or oil will only attract grit and eventually gum the whole thing up.
One advantage to using a key ring is the gap (the cuts where keys are installed/removed) will usually settle at the top making a handy little spray/injection point when you want to put fresh graphite in there.
Good suggestions, guys. I'll check the front preload next time it's warm enough to ride; maybe that's part of the issue. I suspect it's something I'll eventually just get used to with the bike...but the washer/keyring solution is definitely something I'll keep in mind.
I haven't looked at the purge valve connection yet, but the connections for the brake light and clutch interlock were a bit loose--probably end up taping them.
How much in-out play do you get if you measure precisely....instead of about sort of maybe 2-3 mm?
I measure 1mm total.
Not being used to the bike, you might be too tense or have too tight a grip on it.
There is also the chance that your bar-end weights simply weren't screwed in all the way. Factories frequently use a very heavy (pre-dried) permanent threadlock on those bar-end weights and it's difficult to screw them in the entire way during assembly. See if you can reduce the play by tightening it in a few degrees into the bar before resorting to the wash/keyring fix, but don't go too crazy on the torque--50Nm tops, so you don't risk stripping anything.
I just measured...it's right at 1.5mm. The bar end weight on that side is loose...I can spin it easily. I don't know if that necessarily equates to the bolt being loose, though: I noticed the same thing on a new one sitting on the showroom floor, and thought it was odd (the bar end weights on all my other bikes are rock solid), but figured it must be just how they're made.
When I get it over to my shop I might see if tightening the bolt changes anything.
Like I said, I'm not really sure why I'm noticing it on this bike. I've ridden a lot of bikes, and I've got enough miles on this one now that I don't think I'm holding the grips too tight or anything. Part of it may be that the front suspension is set too firm--as I mentioned, it seems almost "bouncy"--and part of it may be that, because the engine/exhaust is so quiet, I can actually hear the thing clacking back and forth as I'm riding.
If you are concerned about it take to your Honda dealer and have it checked over. Otherwise don't fuss with it. There isn't anything much worse than a stuck throttle, unless it would be a total sudden loss of front brakes.
  Josh’s bigger throttle bodies project PowerDubs_imp 50 4,159 10-14-2025, 05:04 PM
Last Post: jikemenkins
  Left side cover removal jeffmazz_imp 24 1,995 07-09-2025, 03:37 PM
Last Post: bflint
  Rattle on right side exhaust / battery CB1100i_imp 4 659 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Throttle cable exposed misterprofessionality 7 1,189 06-12-2024, 11:53 AM
  Left Side Crankcase Gasket Part number. jbird06_imp 1 314 03-26-2024, 08:56 AM
  throttle operation The Gecko_imp 6 576 03-07-2024, 09:39 AM
  ... the perfect side-stand support ? j3gq_imp 17 1,232 07-14-2022, 08:36 AM
  Throttle cable replacement Stoked907_imp 1 267 05-20-2022, 09:35 AM
  Question on replacing engine side cover Ollie 11 762 01-10-2022, 11:21 AM
Last Post: Ollie
  Throttle body sync? Whoops 6 532 07-10-2021, 02:22 AM
