How to...open up the handlebars?
(06-10-2015, 01:12 PM)JustPassinThru_imp Wrote: Sounds stupid, and it probably is. But I need to know how to get the inner plugs for the end weights, out of the bars.
Going with someone's advice, I'm going to try to kill vibration on the handlebars by filling them with lead shot. And yes, I did find some lead shot in a sportsman's store. Shot, funnel, bike and I all got together...and when I took off the end weight, the inner plug just stared at me. No obvious way to get it out.
So...how do I make it happen?
Before you use shot, google Bar Snake or go to this website:
http://www.barsnake.com/
(06-15-2015, 12:10 AM)ChipBeck_imp Wrote:
(06-12-2015, 12:52 PM)JustPassinThru_imp Wrote:
(06-12-2015, 09:07 AM)ChipBeck_imp Wrote: Just,
I have a stock handlebar off the bike. I don't think there is any blockage in the bar but I'll check it out when I get home tonight and let you know. It's possible that when you took the bar weights out you pulled them out of the inner rubber rings. Mine came off when I took those bar weights off and I had to fish them out with a coat hanger. That was probably your blockage. And if they are pulled out those weights are not dampening vibration like they should. Did you take a picture of your weights when they were out?
Chip
Thanks for the info, Chip - but I linked back to the Bar replacement thread (yours?) with good photos. I did get the inner rubber mounts out. One came out as it should, with the inner weight; and the other didn't - and was easily retrieved with a wire.
You could look or try to judge: is there an inner sleeve set inside over the place where the brackets clamp down? Because the amount of shot that went in was almost negligible.
Just,
Yeah that thread is mine. I took my stock CB11 handlebars and rolled a marble that is just smaller than the opening right through them. Those bars are hollow without any restrictions in there at all. I slid some short batteries through them as well. I reload shotgun shells so I poured a ton of #8 shot into the bars from one end with the holes taped over on the other end. That bar holds a lot of lead shot (several pounds). I don't know why you couldn't get much in there. If you lay your bike on its side and take the weight out of the top end you should be able to pour a lot of shot in there.
Chip
Just,
Chip
Wow.
You DID go to some trouble. I'm obliged.
I've figured out what to do: Since I've gotten it to bearable at this point, I'm gonna leave it be for the season. Come fall, when I lay it up...along with other mods, I'll take the bars off. I don't like to rip into clean, new stuff...I have a heavy hand; I tend to break, strip, bung-up things somehow. Hate to trash new stuff.
But come fall, I'll get the bars off. I don't have padding/blocking to lay the entire cycle down without probably damaging things...I'm still amazed that I didn't tear it up more when I dropped it two weeks ago.
So, I have something to do on those cold autumn evenings...too cold to ride but not snowy yet. Wire in a headlight relay and pop off the bars.
I think the CB has headlight relays. Someone chime in to confirm.
(06-15-2015, 09:02 AM)Elipten_imp Wrote: I think the CB has headlight relays. Someone chime in to confirm.
I can confirm that there are none on the '13 wiring diagram. Is just switched.
What does this have to do with handlebars? We try to stay on topic on CB1100 forum Angel Hello
  13 vs 14 handlebars HWdesign_imp 11 978 03-26-2022, 11:54 PM
Last Post: 1973cb750
  No weights in my handlebars =/ ozigoo 5 428 05-20-2020, 02:15 PM
Last Post: ozigoo
  Handlebars - Back to Stock ishouldbuyatacotruck_imp 17 1,581 08-22-2019, 06:44 AM
Last Post: ishouldbuyatacotruck_imp
  Adjusting handlebars on a 2017'RS jtopiso_imp 4 412 06-03-2018, 01:43 AM
Last Post: jtopiso_imp
  Honda oil filter cut open Sam Mac_imp 21 1,325 12-26-2016, 05:48 AM
Last Post: kmoney_imp
  Straight pipes/open headers scout48_imp 59 3,812 11-08-2015, 06:34 AM
Last Post: furious_blue_imp
  Clubman handlebars mgoodie_imp 11 857 11-13-2014, 07:27 AM
Last Post: Django
  Little bit of a clink with throttle open PowderToastMan_imp 7 526 07-28-2014, 12:23 AM
Last Post: PowderToastMan_imp
  Removing handlebars. Anyone have a DIY? silascopathic_imp 8 740 07-27-2013, 02:00 AM
Last Post: 2013 CBXX_imp
