07-09-2013, 12:37 AM
Looking to remove my handle bars and replace them today. I'm sure ill figure it out but if anyone has a walk through that would help speed the process up a bit
Thanks!
Thanks!
Removing handlebars. Anyone have a DIY?
![]() Thanks!
07-09-2013, 01:09 AM
Dont have a diy...if we had one that would be in the How To section. Believe it is very straightforward but you will have to drill pin locators for the switches in your new bars. Measure twice, or thrice, drill once.
07-09-2013, 01:59 AM
(07-09-2013, 01:09 AM)The ferret_imp Wrote: Dont have a diy...if we had one that would be in the How To section. Believe it is very straightforward but you will have to drill pin locators for the switches in your new bars. Measure twice, or thrice, drill once. Thanks man! The holes shouldn't be an issue its just removing the tops of the risers. I'm sure I will get it
07-09-2013, 02:04 AM
(07-09-2013, 01:59 AM)silascopathic_imp Wrote:(07-09-2013, 01:09 AM)The ferret_imp Wrote: Dont have a diy...if we had one that would be in the How To section. Believe it is very straightforward but you will have to drill pin locators for the switches in your new bars. Measure twice, or thrice, drill once. Thanks man! The holes shouldn't be an issue its just removing the tops of the risers. I'm sure I will get it those are just plastic caps that press into allen head bolts. I used a very small thin screw driver to lightly pry them up. It would help to have something without sharp edges.
07-09-2013, 02:35 AM
I just used my fingernail
07-09-2013, 10:31 PM
07-10-2013, 10:57 AM
Post a pic I'm interested, I kinda want different bars. What is the angle of the grip difference? I think I would like them to be swept back more.
07-15-2013, 12:43 AM
(07-10-2013, 10:57 AM)degenex_imp Wrote: Post a pic I'm interested, I kinda want different bars. What is the angle of the grip difference? I think I would like them to be swept back more. http://cb1100forum.com/forum/showthread.php?tid=728
07-27-2013, 02:00 AM
I have tried four different handlebar set ups.
1.Superbike bars on stock risers. 2.Superbike bars on aftermarket risers with Rox setbacks. 3. 919 bars on stock risers. 4. Stock risers turned around (dots on risers turned towards tank) with stock bars. Settled in #4. First two were two close to tank (have scratches on silver stripe to prove it). 919 Bars do not have enough leverage to turn tall skinny 18 inch front wheel and hated stock bars and risers until I turned the stock risers around and pulled handlebars back a bit (read you Could do this in Ultimate Motorcycles road test). Next, work on the bun burner seat |
« Next Oldest | Next Newest »
| removing rear turn signal | modmaster_imp | 12 | 1,057 |
04-20-2023, 10:17 AM Last Post: Lord Popgun |
| 13 vs 14 handlebars | HWdesign_imp | 11 | 1,049 |
03-26-2022, 11:54 PM Last Post: 1973cb750 |
| removing both wheels | Tom_imp | 20 | 1,718 |
05-21-2021, 01:07 AM Last Post: dave |
| Removing bar end mirrors - need advice | Endeavour_imp | 5 | 496 |
08-15-2020, 02:20 AM Last Post: Charlie Bravo_imp |
| No weights in my handlebars =/ | ozigoo | 5 | 454 |
05-20-2020, 02:15 PM Last Post: ozigoo |
| Handlebars - Back to Stock | ishouldbuyatacotruck_imp | 17 | 1,603 |
08-22-2019, 06:44 AM Last Post: ishouldbuyatacotruck_imp |
| Removing stickers | ncgeezer_imp | 14 | 944 |
06-03-2019, 08:07 AM Last Post: Lord Popgun |
| Adjusting handlebars on a 2017'RS | jtopiso_imp | 4 | 432 |
06-03-2018, 01:43 AM Last Post: jtopiso_imp |
| removing rear wheel on CB1100NA (RS) Care needed | Macduff_imp | 1 | 249 |
07-28-2017, 11:54 PM Last Post: the Ferret |
| Removing Cat Converter | HBFL_imp | 1 | 221 |
09-24-2016, 12:56 PM Last Post: Ben70_imp |
