Adjusting handlebars on a 2017'RS
Hi,
Maybe it's a stupid question, but there we go:
From the original set-up, can the handlebars be rotated axialy in their clamps, or is there some kind of notching so the original position can't be changed without drilling or machining of some kind?
I'd just like to try some minor adjustment, to see if I can get the bars slightly higher and closer to me. Just a bit...
Any advise?
Thanks!
The Ferret did a tutorial on adjusting bars (http://cb1100forum.com/forum/showthread.php?tid=3636 ) but all the pictures have gone the way of Botophucket. On the 2010-2014 bikes, at least, it is relatively easy to make minor adjustments of the bars. I assume the 2017 is the same.
(05-30-2018, 08:30 PM)Cormanus_imp Wrote: The Ferret did a tutorial on adjusting bars (http://cb1100forum.com/forum/showthread.php?tid=3636 ) but all the pictures have gone the way of Botophucket. On the 2010-2014 bikes, at least, it is relatively easy to make minor adjustments of the bars. I assume the 2017 is the same.
Thanks!
So there are no pins or nothing that locks the handlebar angle or controls position?
No, once loosened they rotate easily. That's how it is on the 2014. I'd mark the factory position, in some way, so you can see how far you have gone.
(05-30-2018, 11:39 PM)Retsel_imp Wrote: No, once loosened they rotate easily. That's how it is on the 2014. I'd mark the factory position, in some way, so you can see how far you have gone.
Done. Easy peasy!
I have no torque-wrench, so I marked the factory position for the bar and also the bolts, so I was sure I didn't over-tighten them.
It's now raining here, so I haven't been able to test it yet, but I think I'll be more confortable now, even if I have changed the handlebar position just by a degree or so.
  13 vs 14 handlebars HWdesign_imp 11 979 03-26-2022, 11:54 PM
Last Post: 1973cb750
  No weights in my handlebars =/ ozigoo 5 428 05-20-2020, 02:15 PM
Last Post: ozigoo
  Handlebars - Back to Stock ishouldbuyatacotruck_imp 17 1,581 08-22-2019, 06:44 AM
Last Post: ishouldbuyatacotruck_imp
  Adjusting shift and rear brake levers DBM_imp 4 352 08-04-2018, 10:13 AM
Last Post: DBM_imp
  Adjusting Throttle Cable gwallis_imp 8 578 08-23-2015, 12:10 AM
  How to...open up the handlebars? JustPassinThru_imp 13 1,030 06-15-2015, 11:29 AM
  Adjusting the clutch (clutch lever) Olyrider 3 330 03-31-2015, 10:35 AM
Last Post: fiscy_imp
  Clubman handlebars mgoodie_imp 11 857 11-13-2014, 07:27 AM
Last Post: Django
  Adjusting clutch friction point Oboro_imp 5 383 07-11-2014, 04:09 AM
Last Post: tintoy_imp
  Removing handlebars. Anyone have a DIY? silascopathic_imp 8 741 07-27-2013, 02:00 AM
Last Post: 2013 CBXX_imp
