Drive chain replacement time, probably.
I think you just need a chain rivet staking tool and you'd be good to go. No other special tools that I can think of. You might need a cheater bar for the nut on the driven sprocket.
I'm as anal as they come when it comes to lube and chain maintenance.
26/27,000 miles is about average for me when it comes to changing chains and sprockets and I don't do much foul weather riding.
I'm a big fan of the D.I.D. X-ring chains.
(04-27-2016, 03:13 AM)Pauley_imp Wrote: I think you just need a chain rivet staking tool and you'd be good to go. No other special tools that I can think of. You might need a cheater bar for the nut on the driven sprocket.
I have impact stuff in my garage if need be.
Thanks, Pauley. I'll pick up the Stockton chain tool at Cycle Gear while it's still on sale for 40 clams. Happy to share it, too, when time comes.
Thanks, Rocky. Know I could've been a little bit better on chain care, but I was pretty good, considering the rain-free conditions around here. Your info eases my conscience. I probably didn't waste too much chain life, but I'll improve my maintenance a bit, especially taking time to lube after a good ride, when the chain is warm.
Thanks, Randy! Good to know, in case my breaker bar isn't up to the task.
Thanks!
When staking the master link, the manual says the diameter of the staked area is 5.50-5.80mm ( 0.217-0.228in) and if there are any cracks replace the master link, O-rings and plate.
Thanks, popgun! Haven't done a rivet link before, so much appreciated.
I have never done it either. And I forgot to put that the manual also says after you put in the master link and put the plate on it, "Measure the master link pin length projected from the plate. Standard length: 1.3-1.5mm (0.05-0.06in.) then stake the pins and measure as in my last post.
It also says to install the master link from the inside of the drive chain and install the plate with the identification number facing the outside.
And, as long as you have the chain off, you might as well check the chain slider and replace if necessary. It has wear marks, so you can just look at it.
Good luck!
Thanks, popgun!
Looked at several OEM parts suppliers and was just about to order, but I couldn't easily get any assurance that they had all parts in stock and they would arrive in less than a week, which was important to me (new tires and new brake pads also incoming this week).
Called sprocketcenter.com, down in SoCal and they've got JT steel sprockets and a D.I.D. X-ring chain on its way up to me for Friday arrival. Thanks to DAC for tip on those guys. He's used them [url=http://cb1100forum.com/forum/showthread.php?tid=3672&pid=53903#pid53903]before.
(04-27-2016, 11:32 AM)Rolls_imp Wrote: Thanks, popgun!
Cycle Gear still has that staking tool on sale for $40? I bought one about a year and a half ago for the same price Big Grin
It's a good tool, but you have to work slowly and carefully. Especially if you are using the chain breaker to get the old chain off. Too much force, too quickly and the tool head will snap. Same advice goes for the staking tool. Slowly tighten it down, then pull it off and measure, repeat until the rivet head measures the proper diameter. And lastly, don't forget to lube and install the X-rings on the master link before staking.
Good choice on the JT sprockets and the D.I.D. X-ring chain. I've been using that combo for years on all my bikes with no complaints.
  CB1300 headlight bucket replacement spechg 5 384 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 999 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,637 05-03-2025, 10:45 AM
Last Post: Delphisa
  New speed meter replacement ACE_IRA_imp 3 526 02-13-2025, 06:25 AM
  Fork Pipe replacement suggestions danieljrmurray_imp 3 507 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 2,905 02-11-2023, 01:54 AM
  Replacement Battery dave 54 4,081 02-04-2023, 12:41 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,231 11-29-2022, 07:49 AM
  2013 replacement wheel Randy B 8 786 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,496 06-11-2022, 05:51 PM
