Front drive chain sprocket wear
I replaced the rear chain sprocket when I replaced the drive chain, but not the front sprocket. How many miles does a front sprocket typically last before a replacement is required?
I replaced my first one at 40,000 miles and have 29,000 on that one
Thanks for the reply. Good information.
On my '14 std, I replaced frt and rear sprockets + rubber dampers when chain was due. Sprockets had some small visual wear, dampers almost nothing, but chain had its max stretch and a few kinking spots causing vibration mostly in 4th gear.
All were done in August/22 at 66K kms/41K miles, no regrets. OEM parts.
No commuting.
Good news. I have about 28,500 miles on my 2014 now, so I have some time before I have to tackle the problem. Thanks
The front is working more and harder than the rear. You should have replaced it too. It's going around far more often (2.47 x) than the rear. That means it gets more wear. my .02
Disclaimer voice here: The number above was achieved on a spur of the moment guess at a 17/42 sprocket ratio. Your milage may vary. TM
(11-27-2022, 01:05 AM)peterbaron_imp Wrote: On my '14 std, I replaced frt and rear sprockets + rubber dampers when chain was due. Sprockets had some small visual wear, dampers almost nothing, but chain had its max stretch and a few kinking spots causing vibration mostly in 4th gear.
No commuting.
Yea, that's when I did it too. I also replaced the rubber dampers but I don't think it was necessary and they were like $50 if I remember right.
Wait… the guy who sold me my bike said it had a permanent chain.
is it a BMW? lol
(11-26-2022, 11:27 PM)1970Cadillac_imp Wrote: I replaced the rear chain sprocket when I replaced the drive chain, but not the front sprocket. How many miles does a front sprocket typically last before a replacement is required?
I think I saw this same question on a facebook group recently with no answers was this you ?
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,055 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,262 07-30-2024, 10:05 AM
  CB1100 specific wear parts The Gecko_imp 19 1,533 07-01-2023, 10:51 AM
Last Post: bvictory_imp
  Front sprocket bolt cant be moved misterprofessionality 55 4,534 03-13-2023, 12:18 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 991 01-03-2022, 08:30 AM
  How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013 pekingduck 60 4,173 03-07-2021, 09:32 PM
  Another chain and sprocket question bflint 20 1,541 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,729 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 559 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
  Drive Chain upkeep LakeWylieJoe_imp 18 1,120 05-20-2020, 01:36 AM
