Headlight issue
I had the same thing when I installed my Dart Marlin Flyscreen. Like the other guys said, The nuts fall inward as soon as you loosen the headlight basket bolts on the side. You basically need 4 hands unless you do not hot glue the nuts in place!
  Help from the hive mind: Intermittent Starter Issue (2017) JRD 10 576 01-30-2026, 02:16 PM
Last Post: JRD
  Headlight shell Lord Popgun 11 1,571 10-08-2025, 01:17 PM
  2017 MY CB headlight upgrade. 17-CB-002 16 2,313 09-06-2025, 05:00 PM
  Shifting issue Cormanus 31 2,372 05-15-2024, 12:59 AM
  auxiliary 12v in headlight shell Maturecheese_imp 6 659 03-25-2023, 07:14 AM
  Arrow Slip on issue - stock gasket didn’t fit Ddawg1144_imp 4 474 02-21-2023, 07:51 AM
  Delay when using headlight switch? Jgarciajr40_imp 15 1,159 12-05-2022, 07:11 AM
Last Post: max
  Headlight shell acc connector HBFL_imp 2 345 08-28-2022, 08:18 PM
Last Post: HBFL_imp
  headlight adapter j3gq_imp 15 1,200 07-18-2022, 04:12 AM
Last Post: max
  Fuel reserve display issue Banksy_imp 2 292 06-29-2022, 04:37 AM
