07-31-2016, 11:49 AM
While trying to install a windscreen the threads in the light housing (left side facing the bike) appear to have moved.. they are no longer visible in the housing.. What did I do? Thoughts?
Headlight issue
07-31-2016, 11:56 AM
The headlight bucket mounting nuts are welded to a wire holder that is wrapped around the wire bundle in the shell. They set in a space that keeps them from turning when tightening the screws.
If they have moved and you can't use a small probe or something to realign them, you have to remove the headlight and reposition them. Some use hot glue to hold them in place. Here is what it looks like in there: http://cb1100forum.com/forum/showthread....9#pid87099
07-31-2016, 12:05 PM
Thank you, I didn't push that hard, but the threads are totally out of sight.. I'll pull the housing and see what's what.
07-31-2016, 12:27 PM
The hot glue fix is a great idea.
07-31-2016, 02:08 PM
This happened to me. Make sure to put all of the wiring back into the housing after aligning the nuts.
Sent from my SM-N920P using Tapatalk
07-31-2016, 10:18 PM
pwh you don't have to pull the housing (bucket) just the lens and rim. Be careful the rim has to be lifted up in the front if I remember correctly, to be removed. There are 2 small tabs.
07-31-2016, 11:34 PM
Ferret is correct, just pull the headlight, not the bucket. Like in the pic I linked to. And like he says, pull out slightly from the bottom and lift up. You will see how.
08-01-2016, 12:47 AM
The bucket is already loose, as I took out both bolts to do the windscreen fitment (now I know I didn't have to but that knowledge came after it was off).
-Peter
08-01-2016, 01:19 AM
On the good side, look at all you are learning about your bike lol
08-01-2016, 05:14 AM
Once you have the bulb off put the bucket mounting bolts in place to hold the nuts in place, then put hot glue to keep them there.
Sent from me...... |
« Next Oldest | Next Newest »
| Help from the hive mind: Intermittent Starter Issue (2017) | JRD | 10 | 573 |
01-30-2026, 02:16 PM Last Post: JRD |
| Headlight shell | Lord Popgun | 11 | 1,562 |
10-08-2025, 01:17 PM Last Post: Lord Popgun |
| 2017 MY CB headlight upgrade. | 17-CB-002 | 16 | 2,308 |
09-06-2025, 05:00 PM Last Post: pekingduck |
| Shifting issue | Cormanus | 31 | 2,360 |
05-15-2024, 12:59 AM Last Post: the Ferret |
| auxiliary 12v in headlight shell | Maturecheese_imp | 6 | 657 |
03-25-2023, 07:14 AM Last Post: Cormanus |
| Arrow Slip on issue - stock gasket didn’t fit | Ddawg1144_imp | 4 | 469 |
02-21-2023, 07:51 AM Last Post: Charlie Bravo_imp |
| Delay when using headlight switch? | Jgarciajr40_imp | 15 | 1,153 |
12-05-2022, 07:11 AM Last Post: max |
| Headlight shell acc connector | HBFL_imp | 2 | 342 |
08-28-2022, 08:18 PM Last Post: HBFL_imp |
| headlight adapter | j3gq_imp | 15 | 1,194 |
07-18-2022, 04:12 AM Last Post: max |
| Fuel reserve display issue | Banksy_imp | 2 | 292 |
06-29-2022, 04:37 AM Last Post: mattmcuomo@yahoo.com |
