Gas leak ?
(07-14-2016, 08:08 AM)Gumby 1100_imp Wrote:
(07-14-2016, 07:15 AM)Cormanus_imp Wrote:
(07-14-2016, 04:57 AM)Gumby 1100_imp Wrote:
(07-14-2016, 04:52 AM)regularworkingdad_imp Wrote: That used to happen on my VT1100 Shadow Sabre, if the tank was full, and sitting in the sun for a while, like at work. It would just come out the vent tube.
Based on the orientation of your bike in your photo I'm surprised that the fuel doesn't just pour out of the filler cap! Wink
Now look what you've done. RWD's taken his avatar photo down. And I went to all the trouble of fixing it for him.
Sorry,...are you the one responsible for installing the photo oz-side-down? Wink
Now look what you've done. RWD's taken his avatar photo down. And I went to all the trouble of fixing it for him. Too funny! Yes my pic was upside down, so I decided to delete it today. No matter what I did it was upside down, I even edited the photo to be upside down on my camera roll hoping that when I uploaded it here, that it would flip it right side upSmile Nope that did not even work. I also tried to upload a pic to a post, and it came out upside down, so I kind of gave up on pictures on the forum. I already knew I was not that bright, but I did not figure I needed to reinforce that, every time someone saw a reply or post that I did!
RWD, Cormanus fixed your pic and posted it somewhere so you could put it back right side up. I'll see if I can find the thread.
RWD, here it is: http://cb1100forum.com/forum/showthread....#pid141316
(07-14-2016, 09:33 AM)Lord Popgun_imp Wrote: RWD, Cormanus fixed your pic and posted it somewhere so you could put it back right side up. I'll see if I can find the thread.
Thank you! I just saw your msgSmile
It's possible that your gas cap fuel vent could possibly be partially clogged causing an increase back pressure in the tank. If this is the issue and it gets totally clogged your bike will not run
Hello guys.
I just had the same issue with my CB 2013. Based on the comments here, it seems to be related to higher temperatures.
I just checked the bike this morning and there is a small stain of gasoline in the floor, but the vent tube (I assume this is the name of the small pipe below the bike) is completely dry.
It looks like it leaked a little during the day, when it was warmer, but it stopped leaking during night due to the drop of temperature.
Anyway, I'd like to know if the problem is gone, gaby. Could you please comment?
Cheers, and have a nice Sunday, everybody!
Juste trop de gaz dans le reservoir Gaby!
  Slight Oil Leak DutchRutter 22 3,884 05-16-2025, 06:49 AM
  Oil Leak? bvictory_imp 0 210 06-14-2023, 07:05 AM
Last Post: bvictory_imp
  Just found a leak Gone in 60 20 1,342 06-17-2021, 10:18 AM
  slight oil leak Enzofour_imp 3 364 06-07-2021, 12:26 AM
Last Post: michael1954
  Oil Leak - Just got work done and then moved. NickyV_imp 34 2,259 10-15-2020, 02:13 PM
Last Post: max
  Cylinder Head cover oil leak and valve clearance increase. zirconxi_imp 6 632 09-01-2020, 12:19 AM
  Oil leak from pulser cover? skatamutra_imp 4 422 06-14-2020, 07:17 PM
   Oil leak! Help me! steed_boy_imp 43 3,755 02-09-2019, 12:22 AM
   Oil leak... Please help me.. Coldshot_imp 3 770 06-22-2016, 01:23 AM
Last Post: kmoney_imp
  Oil leak..... mattmcuomo@yahoo.com 19 1,137 05-16-2016, 07:42 AM
Last Post: Riko_imp
