2013 ABS forks upgrade :NOT
Josh, no need to justify or apologize for your obsessions. We all have 'em!
The 2017 gives a much better ride STOCK than the 2013 and 2014 ever did. I did put Ohlins on my 13/14 bikes and that made a big difference.I have not have time to take my 2014 with 2017 forks for a ride yet.
I might notice the difference if I went back and test ride a 2013 now. But I moved all of the accessories from my 2013 over to the 2017 so it felt like the bike I was already used to except for the shift points.
Today I rode my 2014 with the 2017 forks for about 80 miles on twisty roads .
The ride was much improved and no regrets spending the money.
Is it worth $ 750 ? ; it is if you keep your bike for some years and/or if you live in a area like WNC or similar roads .
It takes less than an hour to change the forks but you will need a torque wrench.
I’d pay the $750 again all day long, but I didn’t buy this bike ever planning on selling it.
Especially since it is a quick bolt on that allows you to sell your stock forks to offset hundreds of the cost!
I just finished installing (thread to follow) the '17 forks and Ikon shocks - I can't believe the difference. It's like a brand new bike, I can actually ride it again.
Absolutely, 100% worth it. If you don't notice a difference between stock and these upgrades then you either live in an area where the roads really aren't that bad or you weigh $1.25.
I tested the bike out on a back road that is just above a goat path but still paved, the last time I took the CB on it I was pretty much crippled. Today was good.
Awesome.
excellent W/R.
(05-23-2018, 05:42 AM)The ferret_imp Wrote: excellent W/R.
+1
So... did anyone check for oil? Tongue
(05-23-2018, 07:19 AM)PowerDubs_imp Wrote: So... did anyone check for oil? Tongue
Crap, I was going to but I completely forgot.
But like you said, they work so good they must have oil in them. They are almost as good as the inverted forks on my Ulysses.
Thanks Josh for recommending them, you saved my CB1100 from going on the auction block.
  LITHIUM BATTERY UPGRADE: Ballistic vs. Antigravity vs. Shorai E11even_Hunnit 15 1,482 02-25-2026, 11:06 PM
Last Post: Sadorphan
  2017 MY CB headlight upgrade. 17-CB-002 16 2,264 09-06-2025, 05:00 PM
  CB1100 fuel tank upgrade johnnyH_imp 3 445 03-13-2024, 01:31 AM
  Front forks adjustment Olyrider 5 502 05-16-2022, 11:04 PM
Last Post: Sparky80_imp
  Dual bending valves on 2017 Showa Forks jedd_imp 6 604 06-19-2021, 02:29 AM
  oil change front forks Enzofour_imp 7 644 12-06-2020, 08:27 PM
Last Post: jtopiso_imp
  How to adjust the front forks on a 2013 CB1100 and a 2017 CB1100EX. michael1954 13 984 02-28-2020, 07:56 AM
  CB's upgrade rumas_imp 19 1,395 12-01-2019, 09:10 AM
  LED upgrade Skuzzer_imp 13 1,069 06-19-2018, 05:19 AM
Last Post: Skuzzer_imp
  ECM Flash vs. Front Forks (Poll) aschem_imp 16 1,108 03-29-2016, 01:31 AM
Last Post: Motogeezer1949_imp
