Torque wrench woes
I’ve seen soo many people strip out oil drain plugs and spark plugs over the years it isn’t funny!
Torques values must be set MOST of the time with dry fasteners , not always possible ; I use a clicker wrench all the time and set it at the lower value.
Anybody every have this happen to them?
I sheared the threads off a bolt on my CR250 shock linkage with my Sears torque wrench. After some research, I determined my manual was wrong because my friend had a different manual with a lower value. My wrench was inspected by our quality department where I work and it was within acceptable aerospace tolerance limits.
I just discovered that many automotive head bolt torque values are being given in degrees of rotation, and not final torque. My VW head bolt tightening sequence was: Initially torque value (which was low), followed by 1/4 turn, followed by another 1/4 turn, then starting the engine and warming it to operating temperature and tightening it another 1/4 turn.
TTY - tq to yield, also known as stretch bolts.
We use to say 1 , 2 or 3 fingers on the wrench to measure torque!
This topic is timely but a bit disturbing. I've been using a beam-type TW for years and get frustrated when the fastener is at an angle or partially hidden and I have to lay on the ground or stand on my ear to see the needle. I've recently (like this past week) been shopping for a clicker and think I've settled on one made by CDI for Snap-On. But if they can't be trusted, I'll keep struggling with my beam TW and not waste my money.
(08-10-2018, 01:29 PM)LongRanger_imp Wrote: This topic is timely but a bit disturbing. I've been using a beam-type TW for years and get frustrated when the fastener is at an angle or partially hidden and I have to lay on the ground or stand on my ear to see the needle. I've recently (like this past week) been shopping for a clicker and think I've settled on one made by CDI for Snap-On. But if they can't be trusted, I'll keep struggling with my beam TW and not waste my money.
Better ones can be trusted and I check my clicker wrenches once a year against my beam one.
I’m no expert in these things, but I’ve had no trouble with my clicker TW.
  Torque value question Jonnyteabag_imp 9 690 03-10-2023, 01:00 AM
Last Post: 1973cb750
  2014 cb1100 Torque specs for two specific locations Dd808_imp 8 677 09-08-2021, 11:07 AM
Last Post: Dd808_imp
  Handlebar bolts torque value? (CB1100RS -18) Olof_imp 3 447 04-03-2021, 01:35 AM
  Alloy Sprocket woes Ninemeister_imp 22 1,874 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Engine mount bolt torque value TCinNC_imp 43 3,038 07-31-2020, 05:00 PM
Last Post: treedoc_imp
  Shock bolt torque HBFL_imp 9 778 04-11-2019, 07:04 AM
  torque specs? Flynbulldog_imp 30 2,226 03-09-2019, 01:13 AM
  Torque specs HBFL_imp 9 1,291 10-25-2018, 02:25 AM
Last Post: HBFL_imp
  Torque spec for motor mount? PAULIBIKER_imp 3 412 09-10-2018, 07:35 AM
  3 in 1 Filter Wrench, 17mm Magnetic Drain Bolt, OEM Oil Filter, Crush Washers? LordWasr_imp 25 1,711 04-23-2018, 08:54 AM
Last Post: LordWasr_imp
