tire removal
(11-10-2018, 04:02 PM)jdgrego1_imp Wrote:
(11-10-2018, 06:58 AM)redbirds_imp Wrote: If you have the SW Motech bars you can place an auto jackstand under each bar. I do this whenever removing the front wheel and it's rock solid and the bikes weight is supported by the frame.
What are these SW Motech bars you speak of? I went to their website but can’t see anything that looks like it could be used to lift the weight of the front end- thanks for further clarification-
These bars here
These bars here
These bars here
Those are the bars. There are two points where the bars connect to the front frame down tube. The lower connection is a horizontal bar, perpendicular to the frame. This is where you place the jackstand. With the bike on the centerstand, lift the front of the bike with a scissor jack then slide a Jackstand under each crash bar.
[Image: a02315336f1a0aa20b6e2ea58635e80b.jpg]
[Image: d4c06d629d44b892fd75c028ec69b251.jpg]
That's a great idea, redbirds! I've been using a floor jack under the engine, but your solution is much more stable. I've got Over Racing bars instead of SW Mototech, but they attach the same way and have a similar cross bar.
Thumbs Up
These bars here
These bars here
These bars here
[Image: 1fbc714dcebddd8307ca57d52ba8d240.jpg]
[Image: 55701938214b8422edc416054d25df4f.jpg]
Those are nice! I have something similar, but not quite the same- they are closer to the engine / frame and the bar doesn't seem to be as prominent - I might have to look into replacing them for something like you have!
also my pipes seem to be beneath the frame, if I place a jack under them will the weight of the bike crush the pipes or are they strong enough to handle it?
I wouldn't rest a jack under the pipes. Like popgun, I put a piece of wood under the engine, resting on the vertical fins around the oil drain plug, and then use an old car jack to lift the front wheel. I've had both wheels off at the same time with no problems.
These bars here
These bars here
These bars here
Use a block of wood between the jack and pipes. I generally pull up the front of the bike while my wife places the jackstands.
thanks ya-all- I appreciate the help and advise!
[Image: 34dd18b7b4e08357a43f1ecba5562d2f.jpg]
In use.
very nice redbirds :-)
I'll definitely be using the jack stand idea next time I pull the front wheel off....it's a good one.
It's certainly more stable, and, even more importantly, it gives me a reason to use my jack stands that serve almost no other purpose.
  Valve Adjustment and Camshaft Removal dave 5 602 03-21-2026, 04:49 PM
  Left side cover removal jeffmazz_imp 24 1,986 07-09-2025, 03:37 PM
Last Post: bflint
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,588 07-25-2022, 06:54 AM
  Easy bar end weight removal brian10x_imp 6 606 06-06-2022, 01:04 AM
Last Post: 1973cb750
  Air box removal ACE_IRA_imp 23 1,529 09-25-2020, 05:56 AM
Last Post: ACE_IRA_imp
  Fuel Tank Removal Gabby_imp 11 881 06-19-2020, 10:54 AM
  Canister removal Feelergaugephil_imp 2 300 10-11-2019, 10:59 PM
  Handy Cheat Sheet for Maintenance and Wheel removal on my 2017 17-CB-002 12 826 04-17-2019, 12:40 AM
Last Post: ArbitraryThawt_imp
  Heated grips removal Chris potato_imp 7 427 07-26-2018, 11:27 PM
Last Post: itstuantran_imp
  Tire replacement - Not a "Tire Thread" SportsterDoc 12 872 07-18-2018, 06:50 AM
Last Post: SportsterDoc
