Turn Signal Removal
The front and rear are a bit different.
The rear you have to remove the 2 bolts that are also your tie downs. That will let you remove the black peice of metal that your turn signals are mounted to.
The rear most tie down/bolt on each side goes through a plate on the back side that holds the rear turn signal housing in place.
[/quote]
Thanks, that is what I was looking for, makes sense now.
[/quote]No problem, I have the factory rear rack and converted to micro LED turn signals but if you need i will stumble in the garage and get some pictures of what you make need even though it might look slightly different now on mine.
   Water spots removal Bosti 7 805 06-25-2023, 03:20 PM
Last Post: Yata-Garasu_imp
  EX seat removal tpo12001_imp 1 319 06-03-2023, 12:03 AM
   the ultimate signal minder is you j3gq_imp 15 1,343 08-06-2021, 12:35 AM
Last Post: Hovmod_imp
  Is there a turn signal auto-cancel available? ohiorider_imp 38 2,832 12-04-2017, 04:11 PM
Last Post: flynrider
  Turn signal lens discoloration pdedse 5 493 10-03-2016, 02:29 AM
Last Post: AzBob_imp
  Seat removal sharkey_imp 3 377 08-27-2016, 05:02 AM
Last Post: sharkey_imp
  Turn Signal Relay fourfever_imp 2 275 06-30-2016, 10:17 AM
Last Post: Elipten_imp
  Horn and Turn signal position Macross_imp 13 892 06-15-2016, 03:10 PM
Last Post: Brumbie13_imp
  Turn signal relays mn1100_imp 9 750 04-29-2016, 11:28 PM
Last Post: LongRanger_imp
  Dent Removal in the DMV Supervillian_imp 21 1,521 04-15-2016, 12:22 PM
Last Post: Supervillian_imp
