12-27-2021, 08:43 AM
I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.
Turn Signal Removal
12-27-2021, 08:55 AM
(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca
12-27-2021, 09:33 AM
Let us know how you go searching, mvk24. I’ve relocated my rear turn signals recently enough to have a vague memory of how I did it.
12-27-2021, 09:46 AM
I found the wire harness adapters, resistors and some adapters that should work.
12-27-2021, 10:36 AM
(12-27-2021, 08:55 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca Will this help? http://cb1100forum.com/forum/showthread....#pid304616 http://cb1100forum.com/forum/showthread....#pid300300 http://cb1100forum.com/forum/showthread....424&page=2 [url=http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985]http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985
12-27-2021, 10:48 AM
(12-27-2021, 10:36 AM)peterbaron_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:55 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca Will this help? http://cb1100forum.com/forum/showthread....#pid304616 http://cb1100forum.com/forum/showthread....#pid300300 http://cb1100forum.com/forum/showthread....424&page=2 [url=http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985]http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985 Yes thank you very much 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca (12-27-2021, 09:46 AM)Nibis_imp Wrote: I found the wire harness adapters, resistors and some adapters that should work.Those look cool, my turn signals are done but do you have a link for those? 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca
12-27-2021, 11:07 AM
(12-27-2021, 10:48 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 10:36 AM)peterbaron_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:55 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca Will this help? http://cb1100forum.com/forum/showthread....#pid304616 http://cb1100forum.com/forum/showthread....#pid300300 http://cb1100forum.com/forum/showthread....424&page=2 [url=http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985]http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985 Yes thank you very much 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca (12-27-2021, 09:46 AM)Nibis_imp Wrote: I found the wire harness adapters, resistors and some adapters that should work.Those look cool, my turn signals are done but do you have a link for those? 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca https://www.motorcycleid.com/show-chrome...=131385219 Sent from my SM-G986U1 using Tapatalk
12-28-2021, 03:12 AM
(12-27-2021, 10:36 AM)peterbaron_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:55 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca Will this help? http://cb1100forum.com/forum/showthread....#pid304616 http://cb1100forum.com/forum/showthread....#pid300300 http://cb1100forum.com/forum/showthread....424&page=2 [url=http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985]http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985 Yes, it does help with some good info, however, I still don't see how to take the stock signals off. While this is usually fairly simple, and it probably is. When I look at my bike, all I see is a black plate, or something, that looks like it's blocking access to the mounting hardware.
12-28-2021, 03:15 AM
(12-28-2021, 03:12 AM)Nibis_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 10:36 AM)peterbaron_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:55 AM)mvk24_imp Wrote:I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum(12-27-2021, 08:43 AM)Nibis_imp Wrote: I plan on changing to a different turn signal, anyone have any tips on how they come off. I was adding a battery tender cable to the battery today and looked at the signals, but not exactly sure how they come off.I think I did a write up when asked earlier in the year but my memory is pretty poor as of late. I will see if I can find it. I definitely posted pictures and part numbers for the harnesses and turn signals I used somewhere on here at the bare minimum 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca Will this help? http://cb1100forum.com/forum/showthread....#pid304616 http://cb1100forum.com/forum/showthread....#pid300300 http://cb1100forum.com/forum/showthread....424&page=2 [url=http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985]http://cb1100forum.com/forum/showthread.php?tid=9405&pid=290985#pid290985 Yes, it does help with some good info, however, I still don't see how to take the stock signals off. While this is usually fairly simple, and it probably is. When I look at my bike, all I see is a black plate, or something, that looks like it's blocking access to the mounting hardware. The front and rear are a bit different. The rear you have to remove the 2 bolts that are also your tie downs. That will let you remove the black peice of metal that your turn signals are mounted to. The rear most tie down/bolt on each side goes through a plate on the back side that holds the rear turn signal housing in place. 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca
12-28-2021, 03:24 AM
[/quote]The front and rear are a bit different.
The rear you have to remove the 2 bolts that are also your tie downs. That will let you remove the black peice of metal that your turn signals are mounted to. The rear most tie down/bolt on each side goes through a plate on the back side that holds the rear turn signal housing in place. 2014 CB1100, 1981 KZ440 LTD, 1993 Yamaha XJ600 Seca, 1994 Yamaha XJ600 Seca [/quote] Thanks, that is what I was looking for, makes sense now. |
« Next Oldest | Next Newest »
| Water spots removal | Bosti | 7 | 733 |
06-25-2023, 03:20 PM Last Post: Yata-Garasu_imp |
| EX seat removal | tpo12001_imp | 1 | 308 |
06-03-2023, 12:03 AM Last Post: pdedse |
| the ultimate signal minder is you | j3gq_imp | 15 | 1,195 |
08-06-2021, 12:35 AM Last Post: Hovmod_imp |
| Is there a turn signal auto-cancel available? | ohiorider_imp | 38 | 2,480 |
12-04-2017, 04:11 PM Last Post: flynrider |
| Turn signal lens discoloration | pdedse | 5 | 436 |
10-03-2016, 02:29 AM Last Post: AzBob_imp |
| Seat removal | sharkey_imp | 3 | 344 |
08-27-2016, 05:02 AM Last Post: sharkey_imp |
| Turn Signal Relay | fourfever_imp | 2 | 252 |
06-30-2016, 10:17 AM Last Post: Elipten_imp |
| Horn and Turn signal position | Macross_imp | 13 | 771 |
06-15-2016, 03:10 PM Last Post: Brumbie13_imp |
| Turn signal relays | mn1100_imp | 9 | 654 |
04-29-2016, 11:28 PM Last Post: LongRanger_imp |
| Dent Removal in the DMV | Supervillian_imp | 21 | 1,506 |
04-15-2016, 12:22 PM Last Post: Supervillian_imp |
