Threads: 6
After riding my CB for about 100 miles I hopped on the Rebel for a quick ride and noticed I kept hitting the horn by accident. I just realized the placement is reversed for the two bikes. Anyone else experiencing this small annoyance?
Threads: 129
I agree with you. The horn button is not in an intuitive position for me. I'm not one for legislation, but for safety's sake, I think motorcycle controls should be standardized across all manufacturers. At least the shifter is on the left...
Likes Received: 605 in 271 posts
Likes Given: 784
I put a 13 switch on my 14 to standardize my garage. It was driving me crazy.
Threads: 6
(06-14-2016, 06:35 AM)The ferret_imp Wrote: I put a 13 switch on my 14 to standardize my garage. It was driving me crazy.
Oh that's interesting. I maybe interested in that swap in the future if it becomes an issue. Any links or info would be great otherwise I'll search for it. Thank you.
Likes Given: 784
Threads: 6
Threads: 6
Likes Given: 1,002
Interesting article. Down under, where we drive on the left-hand side of the road, cars are made with their indicator stalk on the right hand side of the wheel. Makes sense when you want to operate the indicator with your hand on the wheel while you change gears. If, however, you buy a European manufactured car, they have nearly always left the indicator stalk on the left-hand side of the wheel which means you are forever turning your wipers on when you want to indicate and indicating when you want to clean the windscreen. Or vice versa depending on which way you go. It's a PIA.
Threads: 55
I understand the annoyance the design change causes and see how it could take time to get used to. I don't know if Honda implemented the change for esthetics, to have a big gray button in the center of the swith assembly on both ends of the bars, or for ergonomics. In my opinion the ergos of the new setup are better. As I use the turn signals more than the horn, now the blinkers switch is easier to reach.
Then again, as this is my only motorbike and I don't have enough experience on others it was very easy to get used to it.
My $0.02 worth less than that.
Threads: 71
Likes Given: 20
My BMW K1100Rs had a push button on both side controls. Push left thumb for turning left, push right thumb for turning right.
Being used to that more than 20 years it still leads me to push the horn on the left sometimes, when I intend to turn left.
