Turn signal relays
Has anbody changed his turn signal relays,that could tell me where is located and what type of aftermarked relay do i need.my flashes too fast.this happend after i changed my turn signals.the new ones are not LED.thanks
Didn't we answer this yesterday? Me and Kmoney? Forgot where you posted didn't ya Smile
http://cb1100forum.com/forum/showthread....#pid130785
(04-13-2016, 06:10 AM)Lord Popgun_imp Wrote: Didn't we answer this yesterday? Me and Kmoney? Forgot where you posted didn't ya Smile
Miss a day, you miss a lot. ROFL
thanks guys for responding.I am new to the forum and totally miss your guys respond the first time.thanks again.good riding.
Thumbs Up Hope you get your problem taken care of. That relay the Kmoney referenced seemed expensive though.
I know a lot of people have changed the turn signals. Other than the LEDs, did any of you have to get a relay like Kmoney showed?
I posted up doing a LED conversion using that relay. Resistors not a good way to go IMHO.
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
(04-13-2016, 09:44 AM)Lord Popgun_imp Wrote: Thumbs Up Hope you get your problem taken care of. That relay the Kmoney referenced seemed expensive though.
Talk about an over engineered turn signal system! Just the small difference between between the stock bulbs and 97LL incandescent bulbs causes hyperflash. Why couldn't Honda just use a normal flasher relay...
Sent from my VS985 4G using Tapatalk
I was also too cheap to buy it, I just knew of it from here. I actually don't mind the hyper flash -- it definitely gets the attention of cars behind me when I put my signals on.
I'm sure other honda bikes use the same module as ours. I have seen modules for CBRs that look like similar plugs. I confess I'm too lazy to actually take the tank off and look! But they seem to run about $25. Much more reasonable
I did see another member get a bit perturbed by a post were a member admitted not using the signals because of hyperflash. With that, I'll admit that I don't use mine much at my own risk! I do however primarily use hand signals.
(04-29-2016, 07:59 PM)gbpack89_imp Wrote: I'm sure other honda bikes use the same module as ours. I have seen modules for CBRs that look like similar plugs. I confess I'm too lazy to actually take the tank off and look! But they seem to run about $25. Much more reasonable
I'm not sure about WI, but in CA it is no longer legal to use hand signals if your vehicle has operable turn signals. I suppose it makes sense, because other drivers may not recognize a hand signal when they're expecting to see a turn signal.
Folks around here use turn signals judiciously, even when they're not required (like when following an exit ramp off the freeway or waiting in a left-turn-only lane at an intersection), and then they forget to cancel them.
  Turn Signal Removal Nibis_imp 10 950 12-28-2021, 03:38 AM
   the ultimate signal minder is you j3gq_imp 15 1,195 08-06-2021, 12:35 AM
Last Post: Hovmod_imp
  Is there a turn signal auto-cancel available? ohiorider_imp 38 2,480 12-04-2017, 04:11 PM
Last Post: flynrider
  Turn signal lens discoloration pdedse 5 436 10-03-2016, 02:29 AM
Last Post: AzBob_imp
  Turn Signal Relay fourfever_imp 2 252 06-30-2016, 10:17 AM
Last Post: Elipten_imp
  Horn and Turn signal position Macross_imp 13 771 06-15-2016, 03:10 PM
Last Post: Brumbie13_imp
  turn signal lights LouA_imp 0 169 04-04-2015, 11:04 PM
Last Post: LouA_imp
  Turn signal lights Jaytax_imp 6 366 04-04-2015, 03:01 PM
Last Post: jerrycon_imp
  red signal failure to stop redReno_imp 21 1,542 06-12-2013, 09:32 AM
