Cable tie - reusable?
(05-26-2020, 03:58 PM)zirconxi_imp Wrote: I thought all cable ties are nylon?? Anyway, I only use cable ties to tied wires inside the airbox and battery compartment. Don't think it will be hot enough to melt nylon.
(05-25-2020, 06:44 PM)jtopiso_imp Wrote:
(05-25-2020, 12:17 PM)zirconxi_imp Wrote: I got these in local diy shop.
beware: it's not the same to tidy-up computer cables on your desk that holding cables on a vibrating machine working under wide temperature ranges.
I'd use proper ty-raps (nylon, with metal ratchet)
Not only melting: they can crack or they can come loose if they deform just a little bit. Then things start to vibrate, and everything worsens...
One design can be good for the desk cables, but on the bike... I'd use only proper ones and avoid the cheapest.
And the latch/ratchet (don't know how to call it), should be metal.
Do you meant those metal tie we use to tie exhaust wrap? I had seen my friend tied his exhaust wrap with those. But i think the edge might eat into cables if it were use to tie wires. Nylon cable ties if crack/broken, just ditch it and replace. Until now i haven't had a nylon tie broken on me before i broke it/cut it during servicing.
I think he means the plastic ties that have a metal insert as the locking piece. They're harder to find, but they do not pull loose.
My bad, seems like jtopiso already posted the brand, I had downloaded the catalog and now I understand what he meant.
(05-26-2020, 05:42 PM)pekingduck_imp Wrote: I think he means the plastic ties that have a metal insert as the locking piece. They're harder to find, but they do not pull loose.
Yes: that's what I meant. Thumbs Up
Obviously, it's not the same to hold a brake-line or some other critical component than a usb 5v cable... but my point is the same: not all ties are equal.
  "Seat Lock" cable unseated. 17-CB-002 10 1,009 08-27-2025, 08:19 AM
  Throttle cable exposed misterprofessionality 7 1,211 06-12-2024, 11:53 AM
  GPS power cable The Gecko_imp 10 1,015 10-06-2023, 12:40 AM
Last Post: suhawk305
  Throttle cable replacement Stoked907_imp 1 276 05-20-2022, 09:35 AM
  Cable Lubrication ? bflint 23 1,992 07-26-2021, 08:09 AM
Last Post: max
  Throttle Cable Replacement olekzap_imp 13 1,196 06-21-2021, 09:45 PM
  Throttle Cable oldgoat01_imp 7 1,045 01-15-2021, 06:33 PM
  throttle cable replace x6m_imp 23 1,307 02-26-2018, 06:18 AM
Last Post: Olyrider
  2017 CB1100 RS - Heated grips cable sleeve hdvalente_imp 2 256 05-21-2017, 07:17 AM
Last Post: hdvalente_imp
  Need info - replacing sticky throttle cable Ferrealls_imp 6 521 04-10-2017, 03:39 AM
Last Post: Ferrealls_imp
