Dodgy Kill Switch
On a modern fuel injected bike they're just another place to have electrical problems. Just ask some Moto Guzzi owners.
That's why I mentioned to work the switch from time to time to maybe work thru any corrosion starting.
I did have to replace my kill switch just this summer on my 1978 CB400T. Took me a long time to find one, and it wasn't cheap either. But I wanted to keep the bike 100% because I knew I'd be selling it. Dang cheap Honda part failed after only 36 years! Sad
(11-05-2014, 01:02 AM)ClassicVW_imp Wrote: On a modern fuel injected bike they're just another place to have electrical problems. Just ask some Moto Guzzi owners.
That's probably very good advice - and I'm smart enough to take it Big Grin
Thanks!
Now if I could only remember to put it back into its "RUN" position every time after using it....!
This is obviously a defective switch and no amount of switching it on and off is going to fix it. I've never had a problem with a kill switch before but I will disassemble it and find the cause.
I actually use my kill switch all the time to reduce the load on the ignition switch when turning the bike on. It may be worth it, or not, but it makes me feel better about it. Big Grin
(11-05-2014, 08:22 AM)redbirds_imp Wrote: This is obviously a defective switch and no amount of switching it on and off is going to fix it. I've never had a problem with a kill switch before but I will disassemble it and find the cause.
You misunderstood my comment. My suggestion was not for a repair, but for a possible prevention.
I keep my kill switches off while there in my shop. When I turn on key to check fuel amount, miles etc my fuel pump don't have to cycle on and run. Also a safety factor if my 3 year old grandson was to turn key on he could not start it. Over all the years of riding I have had bikes fall over on me and the kill switch is a fast way to kill motor while your in pain in a bind! Easyer than turning the key.
I use the kill switch occasionally when I want to kill as I come to a stop. Yeh, yeh, I know, no need to tell me. But I have been bitten. Done that and got distracted. Flat battery and bump start. Luckily both times Push Samaritans were on hand. A kill switch that operates with a brush of the hand needs fixing, or replacing.
It's better than a dodgy viffer.
Redbirds, did you ever resolve this? I'm at the rally having trouble with mine. If the switch is fully on, it doesn't run. It has to be positioned about 1/32" from fully on to work properly. I'm wondering if cleaning it will help.
  Delay when using headlight switch? Jgarciajr40_imp 15 1,114 12-05-2022, 07:11 AM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,856 10-08-2022, 12:27 PM
  Turn Signal Switch and Horn Button Locations pekingduck 26 1,939 07-12-2022, 08:04 PM
Last Post: tommymck
  Need a starter switch but none available Kdogg2077_imp 11 956 07-05-2021, 01:56 AM
  Turn Indicator Switch question Scotty_imp 6 510 09-22-2020, 11:58 AM
  Putting 2013 horn/turn signal switch on a 2017 pekingduck 9 638 01-02-2020, 08:37 AM
  2014 Start - Cutoff Switch Question deltamark 16 1,261 04-18-2019, 06:23 PM
Last Post: flynrider
  Horn switch position johan_imp 5 408 06-18-2018, 10:55 AM
  Front brake light switch iffy Ulvetanna_imp 0 170 06-12-2016, 10:38 AM
Last Post: Ulvetanna_imp
