Alloy Sprocket woes
Those Exel's are nice! I want a pair for my Bonnie. Great unsprung weight reduction but the price....
Yes, confirmed, 2014, 5 nuts/M12 for driven sprocket.
In the US, wire wheels came only on the 2017 models, but they use the same 5 bolt sprockets as the cast wheels. Same on 2011 Japan market bikes. On US wire wheels, the disc bolts directly to the hub.
Honda CB1100s all have 5-bolt sprockets with an inner bore of 112mm and a PCD (bolt circle diameter) of 138mm, with five 12mm studs. Just like every Honda larger than 1000cc since 2000, except Africa Twin, which is even smaller. Pretty sure it's not a Honda hub.
Looks like the adaptor ring between the drive flange and the sprocket is just a spacer, with no threads. What is the diameter of the drive flange where a sprocket inner bore would ride? Is it the same 112mm as the spacer? That could determine what bike the hub is from. It is possibly a dirt bike hub.
Metal Gear in Australia make and sell sprockets, disc pads, etc. Here's their page for the spoke wheeled 2014 EX, https://www.metalgear.com.au/part-finder...oke-wheel/
The part number for the OEM Honda 2014 spoke wheel sprocket is 41201-MGC-N20. From the fiche looks like it has 5 sprocket holes.
(09-22-2020, 09:02 AM)pekingduck_imp Wrote: In the US, wire wheels came only on the 2017 models, but they use the same 5 bolt sprockets as the cast wheels. Same on 2011 Japan market bikes. On US wire wheels, the disc bolts directly to the hub.
It's 112mm, same as the stock Renthal sprocket for the CB11.
There is a plain spacer between the hub and the sprocket.
Okay, we'll try to hunt it down. I see the disc side also has a a spacer.
The really confusing part is how they sent a sprocket with the right inner bore, but wrong number of bolt holes - that's an error on them. What is the number stamped in the new Renthal sprocket?
This was the Renthal supplied.
To be fair to the supplier, I ordered a sprocket to fit a stock CB11 and this is what they sent. It's only when offering it up did I realise that the parts on my bike were not stock.
Hey, I'm not complaining, I love those Excel wheels and they are one of the reasons why I had to buy it as soon as I saw the advert.
At the moment it's looking likely that I will have to have a sprocket made which is no big deal aside from the 2 weeks more off the road waiting on the hard annodising.
I should also mention that I have sent the information on the sprocket to Takashi (Samurider) who has recently shipped me the additional White House parts for the K10 package. Parts arrived (great service!) but as yet have had no response on the chain wheel.
(09-22-2020, 10:49 AM)Ninemeister_imp Wrote: This was the Renthal supplied.
All of the listed bikes use 112 bore, but 5 bolts. So their error as they still sent the wrong parts for a stock CB1100, even if your wheel is non-standard. I noticed also that it has 36 spokes vs the CB1100s' 40, but not to worry as the Africa Twin uses 32 spokes. And the spokes are stainless, as they are stamped with "B", signifying Buchanan's Spokes, who are a very high grade wheel and spoke specialist in the US. They won't break.
It is likely an off-the shelf sprocket as they would not have made an adaptor for a non-standard sprocket. Can you look for any casting numbers/letters/markings on the inside of the flange and hub? Then I can see what brand hub it is. I looked through all the Hondas that would have wire spokes with a disc and cannot find any match.
Thanks for your input.
As I said, I can't blame the supplier because I ordered the standard part not knowing that I had a special item on the bike.
I've looked for casting & part numbers on the hub, there are none. Likewise on the spacer ring.
Anyway, the problem is now seemingly solved. Once I realised it was a special part that had to be machined, the supplier suggested they make one from a Renthal blank, then have it hard anodised. Since I don't want to live with the 4 week turnaround, they are sending me the blank so I can spend an afternoon on my lathe and milling machine to bore it out and drill to suit the drive hub (Helps when you're a mechanical engineer Wink ).
I'm now waiting on quotes for hard anodising and PTFE coating...
So now I'm looking at that spacer ring and thinking what weight I could machine off it...
LOL, the fun never stops.
Glad you have a resolution. I might suggest getting 2 blanks, as the setup time and cost of metal treatment would be little more.
What is odd is that you ordered a standard sprocket, but got one with 6 bolts rather than 5, which would not have fit any stock Honda.
Also odd is that the sprocket adaptor was made with a 112mm bore rather than the larger bore of the original drive flange, creating the need for a special sprocket.
  Chain and Sprocket Options? Yata-Garasu_imp 22 1,982 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,216 07-30-2024, 10:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,459 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,172 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 953 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,485 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Broken rubber on front sprocket zirconxi_imp 7 551 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
  Chain & Sprocket Questions arse-onist_imp 12 900 08-14-2019, 09:39 PM
  sprocket changes...one, the other, or both? misterprofessionality 10 787 04-26-2019, 10:11 AM
  clean front sprocket Bronzaar_imp 22 1,504 04-08-2019, 04:49 AM
Last Post: Bronzaar_imp
