LED turn signals
(11-10-2020, 11:43 PM)Lord Popgun_imp Wrote: Solid state.
Thanks PG. Well, arguably things should work.
Is that like deep state, but thicker?
I installed the Motogadget m-blaze pin turn signals on mine, and they did the fast-flash until I installed the Posh relay. The wiring on them is really delicate, so i didn't feel like trial-and-error'ing with soldering in resistors. The relay was ~$100, IIRC, but it's a simple swap.
(11-14-2020, 02:35 AM)12milesout_imp Wrote: I installed the Motogadget m-blaze pin turn signals on mine, and they did the fast-flash until I installed the Posh relay. The wiring on them is really delicate, so i didn't feel like trial-and-error'ing with soldering in resistors. The relay was ~$100, IIRC, but it's a simple swap.
Thanks for the feedback, 12milesout. Would you let us know if the fronts still function as running lights when they aren't turn signals?
I'm 99% certain that they do, but will check tonight.
I think that's what I have,maybe about the size of a dime? Is the relay a direct plug in? I made small bezels to bolt the lights to the rear grab bars and to bolt them to the stock locations on the headlight bracket.
Yes, Yes, and I did the same.
Peking: the front lights do stay on as running lights.
[/quote]
[/quote]
That's good to know. So even by using a different LED-specific flasher, or resistors in-line, you would lose the running light feature. That makes the Posh units worth the expense.
Peking: the front lights do stay on as running lights. Can you send a a few pictures of the lights on the bike,it's going to be awhile before I get mine on the bike. COGNITO MOTO makes some absolutely gorgeous parts. I'll send you a PM.
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 824 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 843 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  Wiring diagram for turn signals. kmoney_imp 21 1,567 05-06-2019, 03:42 AM
Last Post: domeular_imp
  Turn signals acting crazy Headbanger02_imp 10 816 03-30-2019, 09:58 PM
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,396 06-24-2018, 02:39 PM
  Signals flash faster than emergency flashers mattmcuomo@yahoo.com 12 913 02-24-2016, 03:45 AM
  Turn signals at night brougham79_imp 4 395 10-16-2014, 11:45 AM
Last Post: flynrider
  rear turn signals not even ss2wheels_imp 8 845 04-24-2014, 12:23 PM
Last Post: thumper_imp
  How to remove rear signals? HikerToo_imp 6 505 04-03-2014, 03:22 AM
Last Post: CB4ME_imp
  Front Signals Removal 736cc_imp 1 225 03-20-2014, 08:25 AM
Last Post: Randy B
