Signals flash faster than emergency flashers
I don't use the signals very much but when I do they flash twice as fast as the emergency flashers.... all the bulbs are good too. Is this normal for this bike?
Sent from me......
The signals and flashers flash at about the same frequency on my bike. No noticeable difference.
I always use my turn signals (bike and car). Many drivers in the Boston metro area do not however.
(02-23-2016, 06:33 AM)curlyjoe_imp Wrote: The signals and flashers flash at about the same frequency on my bike. No noticeable difference.
Unfortunately I find that MOST drivers in this area don't use their blinkers. I see some use them as an after thought ( in the middle of the turn ).Sad
Kevin
+1 what Curlyjoe says. The same rate on my bike.
First question. Is your bike stock or have you added any electrical device to it or changed to LEDs or something?
I did change the rear signals. I don't think they are LED. They work fine.
Sent from me......
If the new ones are LED they'll still work, but the flash frequency is based off the circuit resistance. You'll need to add a resistor in series to correct the problem.
(02-23-2016, 11:45 AM)Ferrealls_imp Wrote: If the new ones are LED they'll still work, but the flash frequency is based off the circuit resistance. You'll need to add a resistor in series to correct the problem.
Exactly what I was thinking. I wonder, if I don't add a resistor, will it be bad for the system?
Sent from me......
Sorry if I offend anyone here but the opening statement for this post makes my blood boil. There is no justification for not using your turn signals to let all other drivers know your intentions! Accident avoidance is key to any driver, especially for a motorcycle rider. All it takes is one person guessing you are going straight, when you are turning, to cause a life changing, or ending moment! Not to mention how frustrated I get waiting for some idiot, at an intersection, because they did not have the courtesy nor discipline to use their turn signals to let me know, in advance, of their intentions! I am not sure why you care how fast they flash, if you don't use them? Simply remove them and the problem is solved. You always have your arm to signal, as long as you have one, when you do decide that some level of courtesy may be appropriate. A friend of mine lost an arm in a motorcycle accident. Don't go looking for accidents, use everything at your command to avoid them. Especially when riding on two wheels!
Sorry, but this one hit a nerve.
[/quote]
[/quote]
I've been running Rizoma LED signals at all 4 corners without a resistor for over a year with no I'll effects.
A problem with adding the resistor in our bikes is that the front signals are also running lights, and as such the resistor is always doing work (and getting pretty hot). Because of this I just took them out after a while.
Posh makes a digital relay to replace the stock unit so LED lamps work correctly with no resistors. Resistors are not the best option. Look for my post on this subject
2014 CB1100 DLX
2013 CB1100 Std
1990 BMW K75 RT
  Hibeam and hibeam flash button acting up. Jgarciajr40_imp 7 774 04-01-2024, 08:13 AM
  Wire Colors for Signals, Tail Light RedRoevr_imp 10 774 05-01-2022, 06:23 AM
  Changing Placement of Rear Turn Signals eddi0_imp 9 782 06-27-2021, 03:57 AM
Last Post: Gordo_imp
  LED turn signals Jeff in OH_imp 18 1,269 11-15-2020, 07:11 AM
Last Post: FLYTYM_imp
  lazy four-way flashers Gone in 60 6 504 01-07-2020, 08:47 PM
  Wiring diagram for turn signals. kmoney_imp 21 1,352 05-06-2019, 03:42 AM
Last Post: domeular_imp
  Turn signals acting crazy Headbanger02_imp 10 765 03-30-2019, 09:58 PM
  Flash Tuning: How it Works! Red Mist_imp 13 1,091 02-09-2019, 12:46 AM
  Turn Signals/Hazard Lights - Not Blinking/Not Turning on mnm2008_imp 20 1,343 06-24-2018, 02:39 PM
  Question about Power Commander 5 and ECU Flash JohnHighlander_imp 10 718 05-02-2018, 08:20 AM
Last Post: JohnHighlander_imp
