Oil Level
(05-10-2021, 03:05 AM)Enzofour_imp Wrote:
(05-10-2021, 02:24 AM)Olof_imp Wrote: Same experience. Did my first oil change today and ended up filling 3,7 litres. Level fairly much right between the lines.
Did you also change the oil filter?
(05-10-2021, 12:21 AM)Rocky_imp Wrote: I'm a little more "particular" than that - anal Big Grin Big Grin Big Grin
I like my oil level to be just a bit below the upper line.
And what quantity do you put including the filter change?
I don't go by quantity. I put in a safe amount, run the engine, let the oil settle and top up as needed. When I'm happy with the level, that's it.
(05-10-2021, 03:42 AM)franov_imp Wrote: Ciao Enzo,
appena fatto tagliando annuale per la garanzia, moto del 2019 con 3850km.. messi 3.8 litri d'olio, a freddo sul cavalletto centrale, la finestrella è completamente piena oltre al livello "normale", mah.. mi lascia onestamente perplesso.
Così come mi lascia perplesso il costo, per un semplice cambio olio e filtro olio: 201 euro !!!
inoltre hanno usato olio 10w-30, a te quale?
eng:
just done my annual service in order to keep the warranty ok; 2019 EX with 3850 km.. they put 3.8 liters of oil (1,004 gallons), and with the cold engine and standing on the center stand, the oil level window is completely full, way over the normale level.. I'm honestly puzzled if they put too much oil.
as I'm puzzled about the cost, for a simple oil and oil filter change: 201 euro (244,37 USD) !!
also, they used 10W-30 oil, which one do you guys use?
Sometimes I changed the oil filter. OEM filter was about $15 Cdn at the time.
I started using Honda GN4 10W30 ($30 Cdn), then Motul 5100 ($53 Cdn) 10W30, but ultimately settled on Shell Rotella T6 5W40 ($45 Cdn). I really liked the Motul and Rotella, at least from the perceived feelin' in the gearbox.
So cost was about $(15+ 45) Cdn + 13% tax DIY.
Two things: I love how little oil my CB burns! And, I'm sure you're safe to use the figures in the manual assuming you drain your oil. (Maybe it's a little anal, but I lean the bike as far as I can both directions when draining the oil. I've posted here how much extra oil I'm able to get out.)
eng:
I am attaching the dealer Honda in business in Milan since 1928, maintenance sheet so you can see the costs.
I do the maintenance myself and with € 65.00 oil change, Motul 7100 10w30 and Hiflo oil filter.
[Image: 70a80a1f8a09c1501f4a5c420eae1240.pdf]
(05-10-2021, 04:12 AM)Scotty_imp Wrote: Two things: I love how little oil my CB burns! And, I'm sure you're safe to use the figures in the manual assuming you drain your oil. (Maybe it's a little anal, but I lean the bike as far as I can both directions when draining the oil. I've posted here how much extra oil I'm able to get out.)
yes I saw your post, I believe that the difference between the quantity mentioned in the manual and what you see in the window, is because not all the oil is drained, but most of it remains in the radiator and inside the engine.
eng:
I also use Motul 7100 10w30 and pay for a can of Lit. 4 € 57.00
Hi Enzo, thank you for the feedback, but sadly the attachment does not work..
eng:
eng:
I guess today my $67.80 Cdn would be about € 46.05.
  fuel level sensor MBZM Rai_imp 11 1,005 04-11-2023, 11:38 PM
  Low oil level mrded_imp 33 2,403 03-30-2021, 05:51 PM
Last Post: mrded_imp
  High oil level Mixagon_imp 15 1,233 03-22-2021, 10:37 PM
  Oil level difference between check zirconxi_imp 29 2,034 06-27-2020, 09:11 AM
Last Post: redbirds_imp
  Oil level question 562loosenoodle_imp 13 934 03-28-2019, 09:41 PM
  I have two challenges... shifting down and checking the oil level Inhouse Bob 15 1,306 02-11-2019, 01:55 PM
  Checking the oil level LongRanger_imp 27 1,781 10-18-2017, 04:13 PM
Last Post: Jeffhorn_imp
  Oil Level Sight Glass Question olekzap_imp 9 807 07-01-2016, 06:59 AM
Last Post: Ulvetanna_imp
  Oil level went to lower level? mattmcuomo@yahoo.com 6 458 01-23-2016, 03:32 AM
  Question about oil level??? Johnboy_imp 24 1,708 11-06-2015, 01:13 PM
Last Post: kmoney_imp
