05-21-2022, 01:33 AM
Way back in the day, before X and O ring chains, I painted 90 wt gear oil onto a warm chain with a small paint brush, but now I use a spray can of chain lube every so often.
Preferred chain lube?
05-21-2022, 01:51 AM
I have a large, round, flat tin of chain grease, where the idea is to put it on a low heat and, after degreasing the chain, you boil it in this oil for a while. Then take it out, hang it up and let it stop dripping before refitting it to the 'bike.
I did this just once, back in the '60s, but what a messy job! 'O' and 'X' ring chains have put a stop to this practice. I'll be doing it to my Yamaha and BSA chains eventually, both original chains from the 1960s.
05-21-2022, 11:39 AM
FortNine a video on this very subject last year. Wouldn't you know, what Honda recommended won out - regular old rear end gear lube was best.
My bad, it was THREE years ago. Dang, where does the time go? [url=https://www.youtube.com/watch?v=VnPYdcbcAe0&t=5s]https://www.youtube.com/watch?v=VnPYdcbcAe0&t=5s
05-21-2022, 12:08 PM
(05-21-2022, 11:39 AM)Rboe_imp Wrote: FortNine a video on this very subject last year. Wouldn't you know, what Honda recommended won out - regular old rear end gear lube was best. A sexier lube seems to get the most attention. ![]() Gear oil? Not so much.
05-22-2022, 07:51 AM
(05-21-2022, 11:39 AM)Rboe_imp Wrote: FortNine a video on this very subject last year. Wouldn't you know, what Honda recommended won out - regular old rear end gear lube was best. I saw that video, but was surprised because he doesn't appear to follow the instructions for the Chain Wax. I put it on when my chain is still warm from riding. Then I let it sit for 30 minutes or more to harden up. Once the chain wax hardens, it doesn't splatter.
05-22-2022, 03:02 PM
But... but... but... Don't the 'X' / 'O' rings stop the oil/grease getting into the pins where it's needed and where the pins wear?
05-22-2022, 04:53 PM
'X' / 'O' ring chains seem to me to raise the question of whether they need oiling at all. Or is it to lubricate the junction of chain and sprocket?
05-22-2022, 05:51 PM
05-23-2022, 01:30 AM
and to stop the side plates from rusting
05-23-2022, 12:17 PM
Apparently the o-rings keep the lube installed when the chain was made - inside where it's needed and keeps dirt out. Yet lubing still seems to be called for. I thought it was to lube the chain sprocket interface but Fort Nine put the kibosh on that. It does seem to keep outside corrosion at bay.
Anyway, I stopped using chain lube and adopted gear oil (except for the 2014 which has a Tudor auto chain luber which seems to use some sort of gear lube). But like engine oil - you take your money and make your choices.
« Next Oldest | Next Newest »
| Oinker Chain Lube Tool | Gone in 60 | 4 | 484 |
01-15-2025, 08:31 PM Last Post: Cormanus |
| Lube chain with chainsaw oil | mrded_imp | 43 | 2,889 |
06-01-2022, 01:20 AM Last Post: GoldOxide_imp |
| chain lube.. "fluid film" | Chuckk_imp | 14 | 991 |
11-19-2019, 12:57 PM Last Post: GoldOxide_imp |
| Chain Lube | Cormanus | 68 | 4,278 |
07-22-2019, 07:54 AM Last Post: GoldOxide_imp |
| Chain Lube Type and Frequency? | Nappi185_imp | 29 | 1,808 |
09-02-2017, 05:10 AM Last Post: Nortoon_imp |
| Grease Ninja - chain lube applicator | Huladog_imp | 14 | 994 |
01-05-2016, 12:39 AM Last Post: Motogeezer1949_imp |
| OEM chain Lube? | Inhouse Bob | 4 | 375 |
12-30-2015, 02:30 PM Last Post: TINK_imp |
| DLX chain lube technique | DJS_imp | 18 | 1,160 |
05-01-2015, 09:03 PM Last Post: the Ferret |
| Chain lube frequency? | Michael252_imp | 41 | 2,579 |
02-13-2014, 10:52 AM Last Post: ride4now_imp |
