Help - Overfilled Oil, how to remove?
Excellent Thumbs Up Thumbs Up
I recently drained (warm) and filled my oil with 1 gallon fresh oil per manual (reused the old Fram Ultra filter). Bike was on centerstand on level garage floor. Same thing, my oil level window is completely full,above the top fill line. Why is this? Do I need to remove oil to prevent problems? Is the manual's fill recommendation wrong?
(09-10-2018, 05:41 AM)Searcher_imp Wrote: I recently drained (warm) and filled my oil with 1 gallon fresh oil per manual (reused the old Fram Ultra filter). Bike was on centerstand on level garage floor. Same thing, my oil level window is completely full,above the top fill line. Why is this? Do I need to remove oil to prevent problems? Is the manual's fill recommendation wrong?
4 quarts is when you change the filter and oil. The oil filter holds the extra that didn't drain out.
I think the manual states 4.0 quarts if you just drain the oil and reuse the filter and 4.1 quarts if you drain and replace the filter.
(09-09-2018, 02:49 PM)max_imp Wrote: loosen the oil filter , watch the level drop and tighten back up ?
This is not a good idea. When you loosen the oil filter there is a good chance that the rubber gasket will be displaced. I am not talking about it sticking to the engine case, which is also possible. But if you remove an oil filter and look closely at the gasket, it is common for it to be pulled out of position with the type of O-ring like gasket on Honda OEM filters. Rather than loosen it, remove the filter altogether and pour out the oil and then closely examine the gasket before you re-install the filter. Then restart the engine, and turn it off and let the bike sit for 15 minutes and check the oil window.
In the past, I purchased a squirt bottle that comes with a long straw and trigger, like you would find on a bottle of glass cleaner. Buy new so it is CLEAN. Stick the straw into the oil filler hole and manually pump out a small amount of excess oil. You can remove exactly the amount of oil that you want. No mess and you can buy a spray bottle for under two bucks. I store it in my oil drain pan with all of my other oil changing supplies....just in case. I’ve used it maybe three times in 35 years of motorcycling.
(09-10-2018, 08:42 AM)mjturmelle_imp Wrote: In the past, I purchased a squirt bottle that comes with a long straw and trigger, like you would find on a bottle of glass cleaner. Buy new so it is CLEAN. Stick the straw into the oil filler hole and manually pump out a small amount of excess oil. You can remove exactly the amount of oil that you want. No mess and you can buy a spray bottle for under two bucks. I store it in my oil drain pan with all of my other oil changing supplies....just in case. I’ve used it maybe three times in 35 years of motorcycling.
This is actually a very good idea. I was able to use this for my other bike (non CB). But, for CB, it's very difficult to stick the straw all the way to the place where we can pump it out. Unless you have a very thin/slim straw, long and flexible enough for you to get to the oil.
That's a neat idea but disastrous if the tube becomes separated from the trigger handle and slips into the crankcase! With my luck, it'd happen to me.
Just did my first oil and filter change.
Used only 4 quarts (not even 4.1 like the owner's manual states) and it's completely filling the sight glass with oil. Seems super odd. Should be perfect or even a bit low. I'm wondering if the type of filter has anything to do with it. I used K&N.
Anyway, I'm going to loosen the drain plug and drain a bit of oil out. But I think on my DLX the amount to correctly fill is actually 3.9 qts. And I think someone even stated that in a comment.
(08-02-2022, 03:34 PM)ChiefJP_imp Wrote: Just did my first oil and filter change.
Is that with a new filter? Perhaps you need to crank the engine, so some oil goes into the filter.
  How to remove O2 sensor CB1100AZ_imp 10 875 12-13-2024, 09:57 AM
Last Post: inditx_imp
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,363 06-03-2022, 01:16 PM
  How to remove both wheels? RandyBMC_imp 18 1,402 05-10-2022, 11:12 PM
Last Post: Tom_imp
  remove the valve cover from the frame (ex 2014) Enzofour_imp 20 1,292 12-02-2020, 02:06 AM
Last Post: Enzofour_imp
  How to remove turn signal bracket on 2013 model Mtnduc_imp 6 457 10-16-2019, 08:12 AM
  Overfilled oil from dealer Spiderwatts_imp 11 1,187 10-13-2017, 03:17 AM
Last Post: nhawk7504_imp
  Tank, raise or remove? MM300_imp 6 412 06-23-2017, 09:55 PM
Last Post: MM300_imp
  Do I have to remove the rear tire to remove the fender? Nemo_imp 3 341 03-21-2016, 12:11 PM
Last Post: uscgmac_imp
  How to remove bar ends twiin640_imp 4 385 02-23-2015, 07:18 AM
  Remove Seat from 2013 CB11 huxley_imp 9 689 08-19-2014, 01:22 PM
Last Post: gossman_imp
