Shinko 777 tires for my 2017 CB1100ex
(02-26-2019, 11:32 AM)Lord Popgun_imp Wrote: I have 2 questions.
How would you have checked the air pressure without installing the tire (2nd pic)?
How did you put the text balloons on the pics?
. as far as my captions go.. I have an iPhone linked to an apple desktop.. because my phone and comp are linked.. I can answer calls on the comp., text etc.. I edit my pics on the apple desk, then send the pics to Peter, through email.. who is kind enough to post them for me.. I hope Peter doesn't mind me mentioning his name..
Ah, I understand now. Thanks.
(02-26-2019, 11:38 AM)LongRanger_imp Wrote: And my question: Does the 5200 adversely affect wheel balance? I assume you balance the wheel as you normally would, but if applied unevenly, does it create balancing issues?
hi ranger... when I took my tire in to have it mounted, I called my work to the attention of the bike shops mechanic.. he also may find himself involved in a similar project for a customer.. I am keeping him posted thru pics I have taken also.. his thoughts were, it would not affect balance.. the fact being, when I had to take it back in to have the tire removed, allowing me to do my repair, he commented, why don't you add a full second coat all the way around the rim.. the material (3M 5200) seems to be pretty lightweight.. when balancing the rim for the first time, it didn't take many weights to balance it .. (computer balance) ..
I’m guessing Peter doesn’t mind you mentioning his name as when he posts your pics, his name is on the posts! So we all know who did it anyway Smile
Not that it really matters. Except he doesn’t have RLETS. That matters. Wink
http://cb1100forum.com/forum/showthread....#pid231885
(02-26-2019, 12:33 PM)Lord Popgun_imp Wrote: I’m guessing Peter doesn’t mind you mentioning his name as when he posts your pics, his name is on the posts! So we all know who did it anyway Smile
Looks to me like mandatory business trip to Virginia Beach this year ...Tongue
Smile
Bring it! In the Summer when a boat load of Canadians are in town at the ocean front getting sunburned Big Grin. Beer
today I had the shinko777 mounted on my rear wheel .. this was my second attempt.. yesterdays attempt proved very disappointing.. they say, the second time is the charm and this could be very well true.. I checked for leaks around the spokes with soapy water, then dialed in the pressure, as close to 42 lbs as I could.. I measure my pressure with a FOBO tire pressure monitoring system.. I also take a pic of the readings.. tire pressures, tire temp, battery life of sensors, time and date.. this is the best way for me to remember previous pressures .. so tomorrow will be the big day.. tomorrow will tell me if my pressures held.. again, wish me luck !! .. chuckk j.
FOBO is pretty interesting. Here is a link for it: https://my-fobo.com/Product/FOBOBike#feature
(02-27-2019, 12:07 PM)Lord Popgun_imp Wrote: FOBO is pretty interesting. Here is a link for it: https://my-fobo.com/Product/FOBOBike#feature
yes popgun .. that's the one.. I started with the FOBO's when I had my tilting motor works trike.. the only negative so far with it may be the need to replace batteries in the sensors fairly often.. I am doing a test on my batteries right now, to see exactly how long they will last me.. before this test, I would just change them every so often, without actually keeping track..
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 991 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,354 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 939 10-09-2023, 07:51 AM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,254 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 678 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 581 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 tube type tires Mafd2_imp 4 505 02-08-2023, 01:10 PM
  2017 CB1100EX Brake Bleeding M1tch_imp 1 304 03-05-2022, 04:29 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,227 07-19-2021, 08:28 AM
  2017 CB1100EX Dart Marlin Flyscreen TXBikerGuy 4 463 07-23-2020, 11:22 AM
