Shinko 777 tires for my 2017 CB1100ex
#91
(02-11-2019, 07:02 AM)Lord Popgun_imp Wrote: Gold, I have sliders on my bike and they don’t work well as foot rests. Others have had a different experience. Maybe different makes are different. Smile
Bah, unfortunately what I was expecting. I suppose if a grippy surface is added and assuming the sliders are long enough to be practical.
Chuckk's looks long, but I can't be sure from the image. Also, his appears slippery, but can't be sure.
geeeez, where do I start.. you guys changed the subject a few times.. to start with, my emgo shorty reverse cone mufflers (both sides) utilize the existing Honda muffler mount..you know, the same place the rear pegs mount.. easy peasy.. I made my own center stand stop, seeing that the original stop is located on the stock muffler.. my bottom supporting clamp for the backrest is a stock Honda clamp probably from crash bars on a 1100 goldwing.. I have had lots of those 1100's 1000's 1200's 1500's and a few 1800 goldwings they are great clamps.. they are flattened on the "U" part of the clamp for clearance I guess.. I can ride 2 up with the back rest in place or pull 2 pins and remove the backrest, so my baby can hug me .. as far as the sliders, I customized them too.. I bought the longer of the two length plastics, then I used 1/2 in. all thread, putting a chrome crown nut on the out side and two regular nuts on the inside tightened against each other at just the right spot on the all thread so the outside crown nut would be able to pinch the plastic slider and hold fast.. then I used alum. tubing cut to just the right length.. I could have easily made them stand out farther and use them for freeway pegs, but I chose not to.. both left and right alum tubes are of different lengths, because one side case steps out farther than the other.. note: if I remember the all thread utilized one of the motor mount bolt holes. I may have had to drill and open up that motor mount nut, figuring if I had to go back, I would use a nut and bolt in that drilled out hole .. any questions.... chuckk j.
(02-11-2019, 08:59 AM)Chuckk_imp Wrote: geeeez, where do I start.. you guys changed the subject a few times.. to start with, my emgo shorty reverse cone mufflers (both sides) utilize the existing Honda muffler mount..you know, the same place the rear pegs mount.. easy peasy.. I made my own center stand stop, seeing that the original stop is located on the stock muffler.. my bottom supporting clamp for the backrest is a stock Honda clamp probably from crash bars on a 1100 goldwing.. I have had lots of those 1100's 1000's 1200's 1500's and a few 1800 goldwings they are great clamps.. they are flattened on the "U" part of the clamp for clearance I guess.. I can ride 2 up with the back rest in place or pull 2 pins and remove the backrest, so my baby can hug me .. as far as the sliders, I customized them too.. I bought the longer of the two length plastics, then I used 1/2 in. all thread, putting a chrome crown nut on the out side and two regular nuts on the inside tightened against each other at just the right spot on the all thread so the outside crown nut would be able to pinch the plastic slider and hold fast.. then I used alum. tubing cut to just the right length.. I could have easily made them stand out farther and use them for freeway pegs, but I chose not to.. both left and right alum tubes are of different lengths, because one side case steps out farther than the other.. note: if I remember the all thread utilized one of the motor mount bolt holes. I may have had to drill and open up that motor mount nut, figuring if I had to go back, I would use a nut and bolt in that drilled out hole .. any questions.... chuckk j.
Hey, alright Chuckk, thanks for the detailed response.
I haven't followed the tire threads too closely, but it seems the topic of replacement tires always brings up lots of comments. Makes me wonder if stock replacements are difficult to come by or maybe they're very expensive?
(02-12-2019, 01:31 AM)pdedse_imp Wrote: I haven't followed the tire threads too closely, but it seems the topic of replacement tires always brings up lots of comments. Makes me wonder if stock replacements are difficult to come by or maybe they're very expensive?
personally, I like to have as many options as possible.. that is the main reason I have made those brackets to raise my front fender.. raising the front fender was pretty easy.. I think the sealing of my spoked rims will be more challenging.. this will allow me to use tubeless tires without using inner tubes, which everyone seems to agree, isn't a good idea.. I can't wait until my stock d205 is a little more used up and I can get in there and try the 3m 5200 sealer..
chuckk j.
My experience has typically been decent service garages can get whatever you want. Usually it is a balance between time to wait, and how much you are willing to fork out.
pdedse, the OEM tyres for the 2010-2016 models cannot be bought in Australia. Even if you could get them, the OEM Bridgestone tyres for those models wear out on the way home from the tyre shop and so aren’t worth fitting. Other brands that fit the 18” rims (particularly the rear 140) are hard to come by.
I recall Nortoon had trouble finding tyres for his 2017.
(02-12-2019, 06:16 AM)Cormanus_imp Wrote: pdedse, the OEM tyres for the 2010-2016 models cannot be bought in Australia. Even if you could get them, the OEM Bridgestone tyres for those models wear out on the way home from the tyre shop and so aren’t worth fitting. Other brands that fit the 18” rims (particularly the rear 140) are hard to come by.
Interesting. Not understanding (as funny as you word it) the early wear down of the OEM tires. Is this a global thing or localized to the closest manufacturing facility? I don't see the OEMs being quite that terrible, but believe when you say it happens.
Really, how??
(02-12-2019, 07:24 AM)peterbaron_imp Wrote: Really, how??
How what? OEMs suck, or some don't wear down as bad as others?
  Basic Questions About Dynoject V on 2017 CB1100EX dougwene_imp 9 908 12-29-2024, 03:22 AM
Last Post: Karidis
  2017 Honda CB1100EX modifications kennyw 28 2,181 05-09-2024, 09:26 AM
Last Post: FlipModeOne_imp
  CB1100ex Tires pressure, when changed tube to tubeless tory_imp 10 887 10-09-2023, 07:51 AM
  2017 CB1100EX Accessory Plugs TXBikerGuy 13 1,169 06-24-2023, 08:27 AM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 653 05-13-2023, 05:43 AM
  2018 CB1100EX just collected from service Motorsport3_imp 5 556 05-10-2023, 11:25 PM
Last Post: Motorsport3_imp
  2017 tube type tires Mafd2_imp 4 486 02-08-2023, 01:10 PM
  2017 CB1100EX Brake Bleeding M1tch_imp 1 300 03-05-2022, 04:29 PM
  2017 CB1100ex / Flat tire issue and save Senna02_imp 27 2,102 07-19-2021, 08:28 AM
  2017 CB1100EX Dart Marlin Flyscreen TXBikerGuy 4 432 07-23-2020, 11:22 AM
