Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
cbfan_imp said:I bought a small jack from Harbor Freight and it fits under all my bikes............with bike on center stand place jack under front of engine and you can jack it onto the rear wheel which usually gives enough room to remove front wheel.
I would think so. You would need 10 1/2" of clearance between the ground and the bottom of your fork leg to remove it. Sitting on the tire I measure nearly 12".PJV_imp said:if you were to place some weight or strap the rear wheel down, would there be enough room to lift front tire for removal forks? thanks
AzBob_imp said:Hmm, seeing that, the term "jerry rig" comes to mind. Since you said it's stable, I won't doubt you, but using wood to hold up a 550 lbs bike is really not a good idea, IMO.
Don't knock it till you try it. I'm just uncomfortable using the bottom of the engine as a jack point. Much rather use the frame. If I was going to pull the front wheel, I'd add some 4x4 blocks under the lower frame members but for checking the steering head, this works great.AzBob_imp said:Hmm, seeing that, the term "jerry rig" comes to mind. Since you said it's stable, I won't doubt you, but using wood to hold up a 550 lbs bike is really not a good idea, IMO.
Yes, that and freedom of movement lock to lock. That's part of the 600 mile and future checks.Jim21680_imp said:Seems good to me. After I did something similar to this (instead using the engine as a lift point), I thought that might not be the best idea. I'm sure it's fine, but who knows. It certainly wasn't designed for that load.
Regardless of lifting point, a scissor jack is the perfect tool for this, allowing slow & highly-controllable lift.
Lastly, you mentioned checking the steering head.....is that checking for play, I assume? Never thought of doing that before.
