Lord Popgun
Road warrior
Yeah, I spray it on a rag and wipe the wheel. No WD on the tire.
AZ makes a valid point though. Don't spray it on!
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Is that because it will harm the tire, or that it will make it slippery?Lord Popgun_imp said:Yeah, I spray it on a rag and wipe the wheel. No WD on the tire.
That brake cleaner stuff is pretty harsh. Are you sure it won't damage the wheel's paint/clear coat?AzBob_imp said:The problem with WD40 near the rear wheel is you have to make sure you don't get any on the tire. I prefer brake cleaner to get rid of that mess.
No armour all on the seat either. Don't ask me how I know this.Lord Popgun_imp said:Main concern is Slippery. You do not want to make your tire slippery! No WD on it, no Armour all, no tire shine. On the tread part anyway.
If you spray it on, you will almost surely mist the tread and that is a bad thing. Don't want it on the disk or in the brake pads either...
Did you ever live in AZ? Years ago my former neighbor Armor-All'd his seat, even after I advised against it. After slowly rolling down the street, he turned around, goosed the throttle and promptly shifted to a prone position with his legs hanging off the back. Unfortunately, he was twisting the throttle as well as hanging on. When he realized things were going from bad to worse, he just let go. Don't think he ever made that mistake again.Novice_imp said:No armour all on the seat either. Don't ask me how I know this.Lord Popgun_imp said:Main concern is Slippery. You do not want to make your tire slippery! No WD on it, no Armour all, no tire shine. On the tread part anyway.
Elipten_imp said:Well that just changed my thought of testing my ABS as this is my first bike with it. Guess I will wait for a real world experience.
That brake cleaner stuff is pretty harsh. Are you sure it won't damage the wheel's paint/clear coat?The Spaceman_imp said:That brake cleaner stuff is pretty harsh. Are you sure it won't damage the wheel's paint/clear coat?AzBob_imp said:The problem with WD40 near the rear wheel is you have to make sure you don't get any on the tire. I prefer brake cleaner to get rid of that mess.
On clean, dry, sticky pavement, a motorcycle with good brakes is unlikely to lock up the front wheel. More likely, the motorcycle will rotate about its front axle (e.g. "stoppie/endo" -- the rear wheel will come off the ground), assuming moderate rake.The ferret_imp said:Elipten_imp said:Well that just changed my thought of testing my ABS as this is my first bike with it. Guess I will wait for a real world experience.
Eric..I've hit the brakes pretty darn hard on my 14 dlx, hard enough I thought the ABS might kick in, but so far it hasn't that I know about. Never felt any pulsation in lever or pedal. I'm almost afraid to see how hard I have to apply the brakes to make it kick in. i'd like to try it in a big parking lot but then again, like you, I just might wait for the real world experience.
On clean, dry, sticky pavement, a motorcycle with good brakes is unlikely to lock up the front wheel. More likely, the motorcycle will rotate about its front axle (e.g. "stoppie/endo" -- the rear wheel will come off the ground), assuming moderate rake.AzBob_imp said:On clean, dry, sticky pavement, a motorcycle with good brakes is unlikely to lock up the front wheel. More likely, the motorcycle will rotate about its front axle (e.g. "stoppie/endo" -- the rear wheel will come off the ground), assuming moderate rake.The ferret_imp said:Elipten_imp said:Well that just changed my thought of testing my ABS as this is my first bike with it. Guess I will wait for a real world experience.
One shouldn't wonder what max braking capability is... they should be practicing it in a clean, (relatively) deserted parking lot.
