E11even_Hunnit_imp said:
mvk24_imp said:
Olyrider_imp said:
I have added:
ECU re-flash
Power Commander V
K&N Air filter. (not a "power" mod really)
Yoshimura full exhaust
Race-Tech forks
Ohlins shocks
The re-flash didn't really add power. It raises the rpm by 500 revs and provides power to those last 500, but I don't ride nearly that close to the limit. It also removes the "speed limiter" that tells the bike to throttle down when the ECU detects a specific mph.
The Power Commander was night and day difference! Huge difference. Completely changed the personality of the bike.
Did you have a custom tune or did you use 1 of the 3 maps power commander has on the site? This is the second time I've heard people saying they felt a big difference from the power commander but I did not so im thinking maybe I should try a different map?
I believe the previous person that stated this said they used the "Stock with yoshi slip on" map that was online.
I have almost all the same mods as you minus suspension and exhaust
PowerDubs_imp said:
mvk24_imp said:
FLYTYM_imp said:
While my bikes apart it's time to wake up this slug a little. Based on some past info I'm looking at a reflash of the ECM and clean up the air intake somewhat. Will I need a power programmer in addition to the ECM reflash and what can I do to clean up the air intake? Once the bike is back together I'm going to make a KERKER replica slip on. Thanks for the info.
As far as I know the only intake modification that will change performance is opening the velocity stacks up. Powerdubs and a few others have done it.
I'm in middle of doing it but will have to wait to install it when I get a full exhaust.
The TSR plate that goes on the airbox does indeed make a slight improvement at higher revs- very slight though.
The TSR plate that goes on the airbox does indeed make a slight improvement at higher revs- very slight though. I havent seen that donut for sale anymore, wonder if they stopped making it
https://www.ebay.com/itm/HONDA-CB11...390773?hash=item1c95dd45b5:g:8PMAAOSwnpBbSPhR
Not the TSR branded piece but same exact thing, just installed one on my CB along with a K&N filter last weekend
Hey thanks! How does it feel? I know there were some worries about this allowing water into the intake in a hard rain.. thoughts?
I'm shooting some emails out to get quotes to tune the power commander once I drop the velocity stacks in and slap an exhaust on.
Feels great for me personally, there is a bit of an added noise during air intake while on the throttle(which is perfectly fine by me) but it 100% looks like it breathes better than it did with the stock snorkel that pulled air from the rear mudflap, while this is a questionable design-to me- I know the engineers spent thousands of hours getting it right and the bike was designed for the purists and not the hooligans in mind.
I believe Josh(PowerDubs) came up with an alternative where you drill 3 holes on the left side of the air box instead, since he did not exactly like the newfound intake noise of the funnel plate produces vs. stock.
I think whether rain/water is a valid concern for some comes down to and depends on your weather/riding conditions.
I don't ride in the rain much if at all, but as far a I can tell, you should be fine as long as your side cover plate(Right) is properly installed. Rain isn't a big concern for me, but it may be for someone who does cross-country trips with unpredictable weather conditions.
I think I'll be looking into a V-stacks setup as part of my next "performance upgrade"
I think I'll be looking into a V-stacks setup as part of my next "performance upgrade" Nice I think im gonna a order it then. I like touring so like you said I can't always expect perfect weather when I'm on the road for a week and far from home.
But I could always just slap the snorkel back on when I know I have a big trip. I usually go through the entire bike and modify a few things for a trip anyways.
I too would consider myself in the hooligan class lol. I bike can be perfect in every way but its not mine until I make a little difference than everyone else's.
3 of my buddies in the group all got Dynas last year and are on my case to get one as its a better "do everything" bike and fits my riding style much better than the CB. But I keep telling them I don't want a bike everybody else has lol.
