Smart Turn System
Looks like it works pretty good, but man what a clap trap of a bike he put it on lol
My friend Jim ( also a Forum member ) put this system on his 2014 SA. He said it works pretty well, but had problems with the rubber pad system in the turn signal switch that is supposed to prevent the switch from locking in the left or right position ( locking until the rider manually cancels ). He did order and install a 2013 switch housing in order to get his switches in the positions he was accustomed to, as opposed to the location of switches on the 2014 housing. He said the 2013 housing was more compatible with the rubber pads, and worked much better. To each his own, but I don't know if I would want to depend on a couple of rubber pads to modify the switch with 100% reliability. Other than that, the system looks dependable and well designed.
The Safer Turn System was discussed some on here but, as mentioned by 2017EX, the pad thing turned me off to it.
I find either reliable; but there's occasionally a catch with the neural transmitter that affects the reliability of the whole system.
If that is the case other drivers/riders will use their middle finger !
The Smart Turn System offering seems appealing, and by 21st century (2019) availability, should not be profound. The old early '80's Yamaha self-cancelling offering was good, but I would say maybe about 90%+ reliable. Therefore, the rider is still checking the cancel anyway. But that was almost 40 years ago and it was likely very primitive, electro-mechanical in nature and limited to one or two degrees of sensitivity. I speculate the ST2 offering is a full-embedded solution with multiple degrees of sensitivity and sensor signal analysis to get closer to 100% reliability. I suppose ultimately, would a rider get to the level of comfort to not confirm the signal cancel? I reckon for many, that habit is burned into our riding check ritual.
Yes we have been down this path before. I have a 2004 Road King Custom that has self canceling turn signals,always work never a problem. May need to say that Honda could catch up to old tractor technologies. May be should start another thread to up my post count . Hello and welcome to the forum.
Alain Lee_imp said:
Hi GO,
Can you please describe/explain how the Yamaha "Self Cancelling" works?
Hey Alain:
I didn't tear one down. I just used them as a rider.
Given the era in which they worked, I suspected they were quite primitive. I don't mean mercury switch primitive, but possibly a voltage source detection primitive. There might be some online information.
I recall when the rider asserts a turn signal, the engine rev speed was either high (moving and possibly decelerating) or stopped and lower engine rev. In the first case the system voltage is high - maybe 13.5V. When stopped idling at a light the system voltage might be 12.4V. When the rider accelerates again, the engine speed increases and the system voltage transitions back up to 13.5V. Maybe a "capacitor-based timer" begins following the transition of low-to-higher voltage and when it completes, it kills the signal relay using a switching transistor.
Assuming this was somewhat the approach (and I really don't know), the problem was when the rider signaled during a constant velocity turn keeping a decent engine speed. In this case, the signals would often not cancel automatically (which I experienced) because the elevated system voltage was maintained. In addition, I also recall sitting stopped at turns with signals flashing and revving the throttle a few joyful times. That would also sometimes cancel the signals.
I don't recall auto signal cancelling during lane changes at speed working well either.
Of course today, this can all be nicely done in a lightweight digital embedded system and likely a reasonably organized state machine design around some reliable sensors.
m in sc_imp said:
the self cancelling signals on yamahas worked off a sensor in the speedometer actually. there was a pickup that senses over a certain speed it would then trigger a relay and 'kick' the switch off in the control. My rz had one as did some RD400s and XS650s that ive seen. just fyi.
Yes, I would say over the decades Yamaha probably had the most reliable implementation of all the brands. It wasn't 100%, but I would say at least 90% reliable on a healthy, well-looked after bike.
I think Honda's implementation is significantly more technical in nature. Who knows? Maybe it is over-engineered like a German electrical brake light system? I suppose 2020 AT owners will determine in time.
