Poll: How many are having problems with rear Brakes?
AzBob_imp said:
thumper_imp said:
dBuster_imp said:
Regarding the rear brakes, I think they do just fine. Have I locked them up? NO and I do not plan on locking them up. Like it was mentioned before, the rears are not for main stopping power on your bike.
hmm Lets see, rear brakes count for 30% of your braking power... The other 70% is supposed to come from the front...
If you are mainly using that rear brake for stopping... I removed my comment... :s *shaking my head though* :s
thumper_imp said:
ABS--Never use the rear brake, so non-issue.
I just had to quote this from Thumper... why, if your not using your rear brake would you get an ABS equipped bike? The ABS applies the front when you apply the rear brakes. Not the other way around... or does it? If it is flipped around then you are using the rear... :-/
I bought an ABS bike so I won't accidentally lock the front brake, whether by panic, compromised surface condition, or a combination thereof.
I think you're confusing the "Combined" aspect of Honda's "Combined ABS" with the ABS aspect. On this bike, activation of the rear brake will also activate "some" front brake--that is the "combined" aspect. But, activation of the front brake only activates the front brakes. Should you brake hard enough to activate the ABS, you get ABS whether you use the front lever only, the rear pedal only, or a combination of both. You don't need to brake hard enough to activate the anti-lock, in order to get "Combined braking", should you choose to use the rear pedal.
And, I teach advanced riding on a racetrack environment, and I'm usually riding a mountain road at a spirited pace. So I'm usually in a riding position where the balls of my feet are on the pegs, for body steering of the motorcycle.
It's not for everyone, and we're all free to choose how we're going to control our own motorcycle. I'm quite adept at using the front brake only, I can trail-brake deep into a turn that way, and so that's my choice and style, based on the way I ride.
I assume you ride with your hands on the bars/clip-ons. If that assumption is correct, attempting to steer with anything other than the bars/clip-ons is extremely inefficient, given the physics involved.
http://www.classrides.com/_about/what_we_teach.html
The ferret_imp said:
AzBob' pid='10121' dateline='1375740812 said:
As far as I can tell, you've been riding forever, so far be it from me to say how you should ride. However (you knew that was coming), at around this time you'd have to be downshifting anyhow, so front brake application would be the norm. Unless you're coasting into the turn, in which case "you're doing it wrong."*
Yea been riding awhile, since 1965 on the street. We were taught brake rear to front ie: hit rear brake first, front brake second. I may have been doing it wrong for 46 years now. I don't always downshift for a turn, sometimes I want to be in a certain gear, but just want to be going a little slower in that gear.
Hit the front brake alone entering a turn and several things may happen, (1) front end may dive, upsetting chassis,(2) it may even cause it to slide out, causing a low side or (3) bike may stand up straight ruining your line.
For what it's worth, the You and your motorcycle riding tips from Honda that came with your motorcycle says, and I think I can quote this verbatim, .."always apply both brakes at the same time"
I know some aficionados these days say they never touch the rear brake, on a disc brake equipped bike, but that's not going to happen with me, other than setting up for a turn where I tail brake (use the rear brake only) to scrub speed, I always use both brakes when slowing down or stopping.
I don't use my motors compression to slow down considerably, that's what brakes are for...
Also front brakes only, will only provide up to 70% of your bikes ability to stop. Why would you give up nearly 1/3 of your braking power by foregoing use of the rear brake? I've never understood that philosophy.
Given, as you yourself state, that the front brake does most of the braking, that seems like a good way to give up precious feet in an emergency situation. But if it's muscle memory for you, stick with it. At this point, changing would probably do more harm than good.
Quote:I may have been doing it wrong for 46 years now.
Just because we used to do something a certain way for a long time a doesn't mean that way remains the most efficient. For instance, when slipper clutches came out, the need to blip the throttle on downshift disappeared. People still do it on bikes so equipped but it's totally unnecessary.
Quote:Hit the front brake alone entering a turn and several things may happen, (1) front end may dive, upsetting chassis,(2) it may even cause it to slide out, causing a low side or (3) bike may stand up straight ruining your line.
Braking of any type, including engine braking, will cause the front forks to compress due to weight transfer -- there's no getting away from it. Same with the bike standing up -- it stands up because the velocity of the wheels is lessened and therefore gyroscopic force they exert is lessened and they can't keep the bike's center line in the same plane of travel as easily. The amount to which these occur is a function of the braking force applied. Since the front brake applies much more force than the rear brake or engine braking, it appears as if the front brake cause the bike to dive more, but this is just an illusion based on the fact that the front brake is slowing the bike more.
Quote:For what it's worth, the You and your motorcycle riding tips from Honda that came with your motorcycle says, and I think I can quote this verbatim, .."always apply both brakes at the same time"
I always use both, even on my CBR where 100% of the braking force is easily applied by the front brake alone. Worst that happens is my rear wheel is in the air a bit doing nothing. I do it because I ride the two different bikes and I like my panic reactions to be the same regardless of the hardware, if possible.
Quote:I know some aficionados these days say they never touch the rear brake, on a disc brake equipped bike, but that's not going to happen with me
It depends on the bike. As I mentioned, on my CBR and probably every sport bike, the front brake can lift the rear tire off the ground. In that case, it's obviously providing 100% of the braking force. On a standard like the CB, or a cruiser, the wheelbase is longer and that's less likely to happen. I am somewhat ashamed to say that I haven't yet practiced panic stops on my CB, so I don't yet know if the front brake is powerful enough to lift the rear tire.
Quote:I don't use my motors compression to slow down considerably, that's what brakes are for...
Agree, but in local traffic, I like to be in an appropriate gear for "oh crap! here comes xyz" moments, and so engine braking happens quite a bit for me. There is a bit of controversy whether engine braking is bad for an engine or not, and as near as I can tell, there is no consensus on this issue.
When all is said and done, I think the best thing any motorcyclist can do is avail oneself of the many, very good resources available (Proficient Motorcycling, [url=http://www.amazon.com/Twist-Wrist-Basics-High-Performance-Motorcycle/dp/0965045021/ref=sr_1_1?s=books&ie=UTF8&qid=1375913848&sr=1-1&keywords=a+twist+of+the+wrist+2]A Twist of the Wrist II, and [url=http://www.amazon.com/Total-Control-Performance-Street-Techniques/dp/0760314039/ref=sr_1_1?s=books&ie=UTF8&qid=1375913869&sr=1-1&keywords=total+control+lee+parks]Total Control are three book titles that come immediately to mind; while the last two lean toward sport bike riders, the techniques covered apply to any and all motorcycles) and then go out and practice what the books teach. Perhaps taking one of the intermediate and/or advanced courses provided by the Motorcycle Safety Foundation (or the BRC if one has not taken that, or haven't taken any course recently). This is directed more toward the general populace than the quoted author.
That's my $.02. I hope everyone enjoys their bikes as much as I do mine! :-)
AZBob you make a lot of good points, and I didn't take offense at your post or feel it was directed toward me specifically. I should be clear, I am perfectly comfortable using the front brakes, hard, up to the point of lock up if necessary. I use them every time I brake, with the one exception of just scrubbing a little speed, maybe 5 mph if necessary prior to entering a turn. But in order for that to happen the rear brakes must function as a brake, and as verified by another ride this afternoon, even though I just removed the pads, cleaned them and scrubbed the disc, mine are just not up to the task.
I too ride multiple bikes, on any day I may ride one of 4 in the garage. On three of them the rear brake works well. On one it doesn't, my CB. I know what properly operating brakes feel like, and my CB has an obvious issue. I have not bled the back brake, but as it's under warranty, I think I will let the dealer do that. I can ride the CB without issue as far as braking goes, by using the fronts, but I know when I depress the rear brake pedal and virtually nothing happens, that it's not right. Apparently at least some others are having the same issue.
I assume you ride with your hands on the bars/clip-ons. If that assumption is correct, attempting to steer with anything other than the bars/clip-ons is extremely inefficient, given the physics involved. Freddie Spencer and Reg Pridmore would certainly take one to task for that comment.
And Keith Code would take one to task for theirs.
Quote:The histrionics of road racers pretty much settles it as they are climbing all over the bikes, now more than ever (dragging elbows at 60 degree lean angles).
Not really, one has to understand the physics of what's happening. Hanging off the bike doesn't turn the bike any better (or at all), it just shifts the weight, moving the bike's center of gravity, allowing the bike to go faster at a given lean angle without losing traction. Hanging off more allows the rider to carry more speed through the turn, it doesn't turn the bike any better.
Push the inside handlebar/clip-on to actually turn the bike. Keith Code's "No BS" bike demonstration makes it more than obvious how this works.
" Hanging off more allows the rider to carry more speed through the turn, it doesn't turn the bike any better. "
That seems like the definition of turning better.
Brakes..we are talking about brakes
I'm very happy with the brakes: front and rear. IMHO the rear brake should be not as strong as the front. The front is the main and rear is "backup". Brakes on my FZ1 are very strong front and weak rear. Even so I've slid the rear during aggressive cornering and have learned to rely only on the front when riding fast in the mountains. You may not agree with me but it works for me and I don't have chicken strips on either bike.
New update Aug. 8th. 2013 Okay,here is what I got now. My SBS brake pads are squeaking at slow speeds (stopping) You know: the rear brake!! And it is still not working right! I do know how a brake should work. I am thinking about calling or writing Honda in Califorica. This could turn into something crazy! I just want a back brake that works right! I am tired of being Fred Flintstone! God Bless..
Jayimpalaman
Jayimpalaman
Lol, I hear ya brother. Talk to them for me too!
Brakes great. I notice a ring on the rear caliper and there seems to be a wire, we don't have just rear abs do we? Need to get the shop manual out and see what that is for. non abs model vin 1251
Lol again we are not trying to see who can lock them up, but who is unhappy with their rear brake performance in slowing the bike down.
Run it up to 50 mph, pull in the clutch, and try and slow down or stop using the back brake only ( don't use the front) and see if you are happy with the performance of the back brake.
Yes we know you should use the front brake. Yes we know the back should be less powerful than the front. Yes we know the back is secondary and used to aid the front in stopping.(The rear brake should supply up to 30% of your braking power). We know all of that.
When I do the test above, the is no feeling of stopping, or even slowing down. It just keeps on going for a long long way, with little reduction in speed. My STs rear brakes will slow you down and stop you, my Majestys rear brakes will slow you down and stop you. my CB's will not.
Remember that unless you've radically modified the brakes on your ST, they are linked--using the lever gives you some back braking, and using the pedal gives you some front braking.
From Rider magazine, September 2002:
"Hitting the rear brake pedal activates the two outer pistons on the rear disc, and the center piston on each of the front discs."
A couple of other factors--our CB11's have very skinny tires, and the longitudinal weight distribution of your Majesty scooter, which has its engine at the rear, is much different than a motorcycle.
Thumper the linked system is only on the abs models. It is easy to test. Put bike on centerstand. Make sure sidestand is up. Start bike. Put it in gear and let out clutch. rear wheel will spin. Pull in clutch and grab front brake lever. If it is linked it will stop or slow the rear wheel. If not they are not linked. If you depress the rear pedal the wheel will stop. Since there is no weight on the rear it stops easily on the stand.
If you want turn off bike and have someone put weight on back getting front wheel off ground. Now manually spin the front. Now depress the rear brake pedal. If you have linked brakes the front wheel will slow or stop. If not no linked brakes.
I just did this test in the driveway. Grabbing front brake has absoluetly no effect on rear wheel spinning. Pushing rear brake has absoluetly no effect on front wheel spinning
