Houtman_imp
This is my first bike with FI and I too thought that the throttle response was a little jerky.I measured the grips on my 79 CBX and 94/95 CB1000 and the throttle grips are exactly the same size and the grip profile is also the same (no change over 34 years!) Therefor I do not think that the size is the culprit but more that I have to get used to fuel injection and be easy on the throttle.There is nothing smoother in my opinion than the throttle response on a well adjusted 6 carb Honda CBX.I will order a set of the Grip Buddies to see if that makes some difference on the CB1100 but I still think that the fuel injected bikes need a smoother action from the rider.Deanohh_imp said:CB is a whole lot better than most. Learn to be smooooth on the throttle. Its worse if you're going slow... You can shift down or if already in 1st try to be accelerating a little or decelerating a little, or if going real slow, don't just use throttle to speed up but pull in the clutch a little as if you're starting from a stop. A perfectly steady slow speed with only the throttle is probably impossible.
careful not to set chain too tight ...you're going to have some lash in the drive train no matter what.
