ss2wheels_imp
Been there
Please someone tell me what is the stock shock length on my DLX it appears to be 14.25, I really want to go about 1 inch lower.who makes them in shorter lengths:huh:
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
ss2wheels_imp said:Ferrit, I do plan on bringing the fork tubes up in the trees but I really want shorter shocks also. I am not concerned with losing some lean angle as I dont ride very agressively, at 5ft4 I dont have much choice. I have lowered many bikes this way and I never scrape anything.If necessary. I can even have the kickstand shortened.Also tell me about bar risers that will work with stock cables and wires?
You might first look into reshaping / lowering the seat. That might prevent the need to mess with the suspension and at the same time would raise the height of the bars in relationship to the seat.ss2wheels_imp said:Ferrit, I do plan on bringing the fork tubes up in the trees but I really want shorter shocks also. I am not concerned with losing some lean angle as I dont ride very agressively, at 5ft4 I dont have much choice. I have lowered many bikes this way and I never scrape anything.If necessary. I can even have the kickstand shortened.Also tell me about bar risers that will work with stock cables and wires?
SW Motech has bar risers that should work with the stock cables, especially if you raise the forks in the triple clamps. I have used them on a V-strom, Bonneville and Tiger 1050 with no cable reach problems.ss2wheels_imp said:Ferrit, I do plan on bringing the fork tubes up in the trees but I really want shorter shocks also. I am not concerned with losing some lean angle as I dont ride very agressively, at 5ft4 I dont have much choice. I have lowered many bikes this way and I never scrape anything.If necessary. I can even have the kickstand shortened.Also tell me about bar risers that will work with stock cables and wires?
Perhaps go slower? I've never even come close to bottoming the bike out over a speed bump and I'm north of 250lbs with gear and backpack.Randy B_imp said:Which bike did you get? I have issues with speed bumps bottoming out on the catalytic converter at stock height, and I'm not the only one with this issue.
I think the DLX has more ground clearance due to the change in the pipes.
