Lord Popgun
Road warrior
There is a procedure in the service manual. The test is easy, but normally you do it with the pump removed. Might be able to do it if you can move the float up and down.
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
While we are awaiting replies from gurus, my first thought is a bent float rod or defective sender. Dealer may measure voltage to meter, but likely will need to pull the float/pump unit.The ferret_imp said:well we have some pretty smart fellas on this board, but the OP shouldn't have to do his own diagnostics. This is clearly a warranty issue.
if you fill the tank and it only shows half full ( I believe that's what the OP is saying), Honda Canada Service Rep should be able to diagnose and authorize warranty replacement of defective part. If I were the owner of a brand new unit, I would not want to be pulling my pump assy, float assy, or sending unit for testing. That's crazy. (BTW I had a Yamaha Majesty Scooter that did the same thing and Yamaha replaced the fuel pump assy under warranty which fixed the problem)
That said our electrical gurus can probably figure it out.
In the meantime, I would use one of the trip meter for monitoring fuel/mileage by re-setting every time I fill up and calculating gas usage on my smart phone, multiplyiing mileage x tank capacity to figure when I need to stop for gas.
When completely filled, mine uses 1.8 gallons when 3 segments disappear.johnny_longhair_imp said:Thanks for chiming in all. To clarify, gauge shows full when full. But takes almost 3/4 of driving before showing 1/2. I always go off trip meter and I always fill on center stand and it’s always FULL. it’s the bottom half that is unreliable. Also, I won’t be performing any surgery on the machine myself (I could, but why?) the dealer will be taking care of it under warranty. The only reason Service sent me to the forum was because they had not heard of this issue. Not that they didn’t believe me or were trying to put me off.
peterbaron, I've got 4000 km on the bike only so far, but I consistently get 300km on a tank with 2.5 to 3 L remaining ie. Fill 13 to 13.5 for the supposed 16.5 L capacity. I track this religiously. Tank reads 1/2 after 200km. Drops fast to 1 block around 250. Should start to blink and give me readout of 60-80km remaining. It has a few times. But more often than not, it just goes to "--" which,according to the manual, is when 1 L is remaining. Which is BS since I've ridden 60km with this displayed. I'm never going to rely on the computer, but new bike, should work.peterbaron_imp said:This is what I now understand :
1* gas meter has 6 bars when full
2* first/top half of gas tank makes more km than 2nd/bottom half..so in digital meaning you make i. e, 170 km with first half and 3 bars left on meter and only 130 km with the 2nd half, correct??
When 1/2 full, meeter always "hangs" in this position longer and after longer time starts dropping faster.
If this is the case , I would say there is nothing wrong with it, I see all my vehicles like this, not just CB.
Correct me if my understanding is wrong, please.
I think the signal is buffered and needs time to change.SportsterDoc_imp said:I think the signal is buffered and needs time to change.peterbaron_imp said:Generally, yes,... it also might be mechanically stuck (interference) from 1/2 to full tank, while working OK from 1/2 to empty.
If I remember correctly, fuel pump ass-y unit has a 4 pin square black connector.
How about 1/2 - 3/4 fill and shaking CB sideways , and then top it up, as a very simple test, without electrical knowledge. I do not think meter will show changes while shaking.
So try it if you want, does not cost anything.
:beerchug:
My 2014 standard is very consistent:
Each segment is about 0.6 gallon, until the last segment.
I did not follow Johnny's "issue". Did it still read "1/2" (3 segments) after completely full?
If so, float rod is likely obstructed or damaged, especially if something thrust into its path.
The dealer can probe the voltage output.
I use trip 1 for refueling and trip 2 for day's outing.derek.dalman_imp said:I think the signal is buffered and needs time to change.SportsterDoc_imp said:I think the signal is buffered and needs time to change.peterbaron_imp said:Generally, yes,... it also might be mechanically stuck (interference) from 1/2 to full tank, while working OK from 1/2 to empty.
:beerchug:
My standard 2014 is very consistent as well. I always assumed each bar is a half gallon making up the first 3 gallons and then when the final bar switches to blinking that is the remaining .8 gal of "reserve".
peterbaron, I've got 4000 km on the bike only so far, but I consistently get 300km on a tank with 2.5 to 3 L remaining ie. Fill 13 to 13.5 for the supposed 16.5 L capacity. I track this religiously. Tank reads 1/2 after 200km. Drops fast to 1 block around 250. Should start to blink and give me readout of 60-80km remaining. It has a few times. But more often than not, it just goes to "--" which,according to the manual, is when 1 L is remaining. Which is BS since I've ridden 60km with this displayed. I'm never going to rely on the computer, but new bike, should work.johnny_longhair_imp said:peterbaron, I've got 4000 km on the bike only so far, but I consistently get 300km on a tank with 2.5 to 3 L remaining ie. Fill 13 to 13.5 for the supposed 16.5 L capacity. I track this religiously. Tank reads 1/2 after 200km. Drops fast to 1 block around 250. Should start to blink and give me readout of 60-80km remaining. It has a few times. But more often than not, it just goes to "--" which,according to the manual, is when 1 L is remaining. Which is BS since I've ridden 60km with this displayed. I'm never going to rely on the computer, but new bike, should work.peterbaron_imp said:This is what I now understand :
Interesting behaviour. I have not seen it. I will pay even more attention now.jimgl3_imp said:mine worked very well until Sunday. I left the house headed to church with it flashing, but the range said I had 49 miles left. I went about 2 miles and it ran out of gas with the range still saying 30 miles left... guess I can no longer trust it.
