Fabbing an adaptor to move signals back. May duplicate for y'all
I like... But where on the napkin would it indicate any rubber dampening? Or is that not a concern? ;)
Sent from my XT1055 using Tapatalk
Most likely a gasket at the attachment point. If you use the original light it has it's own damper. I'm going led so not as concerned about vibration.
So. The final will be larger to cover the mount area better and a bit of work on the rear cover not dabbed yet. But. We are in the right direction. Final product will be painted to match the rail silver paint.
Its looking good to me!! I can't wait. :)
it is looking good!!! How are the chances of getting a top down photo? I am trying to get a grasp of looks. How sturdy is the extension? I am asking as it looks like it might be back far enough behind the seat and maybe a bar from one side to the other for added stability?? Or am I reaching there....
just thinking while listening on a conference call at work and not really into the call... not for my department...
No bar required. It's aluminum. Super light. And it tightens to the rail nice and firm. May add a tab to insert into the rail where there is a slot to eliminate swing. But need to set the angle fixed for that. Some may want the extension level to ground. Some may want to flow with the angle of the rail slightly upward. So may or may not do a tab. It's all super light. Looking for top down pic
Not a top view but these may help
Now that is a question. Inline with the rail or parallel to the deck... Hmmm
Still looks good though! Mighty good! Now to test with some bags to see if they are clear of the bags
None.
Have to maybe post a thread later and see what quantity would be in relation to cost
I'm in!!
Will our stock lights fit? Sorry if thats been asked...
It was being designed to accommodate the stock signals but I believe an electrical harness extension would be required.
dbuster,
Great! I'm an electronics tech so wiring it or getting an extension as shown above somewhere is no biggie.
Thanks.
There will need to be a wire extension. No biggie for most people to handle. The wire will run through the chase shown as to be clean of wires
dbuster,
Thanks.
Are you going to be making the extension harnesses to go along with this wonderful fabrication work?
Was just pointing out that it would work with our stock signals but you were on your own for the harness extensions. Basically I answered your original question I thought...
