Damfino_imp said:
The ferret_imp said:
bars are not correct so I assume cables incl hydraulic hose may not be correct either..but it does have a set of original rlets going for it
tires are good but wrong pattern, valve stem caps are incorrect
looks pretty good, even chain looks clean
Mickey, I'm surprised you didn't catch the incorrect tank! I'm not referring to the paint scheme, I'm referring to the petcock being on the left side, which only the K5-K6's had.
He does mention in his notes that he replaced the tank...
Aftermarket ignition switch too, probably Emgo?
I'm getting old
Ignition is in correct location. Many used to move the ign switch up to the handlebar bracket with a V shaped chrome bracket, but correct location is under the tank left side front as I remember it.
