rboe
YOu still need some lube for the chain - sprocket interface.
Rboe_imp said:YOu still need some lube for the chain - sprocket interface.
Since adding the Tutoro unit, I would say I wipe down the chain twice a year. I don't really have to, but I do and it takes only about a minute. That is, while on center stand I soak the chain with WD-40 for as long as I have time for. Take an old cotton t-shirt (or whatever) and wipe off the grime by grabbing the chain and turning the rear wheel. The oiler will do the rest during the ride.Cormanus_imp said:GO, do you clean the chain periodically or does it just get grungier every ride?
Good luck with whatever your ultimate solution you adopt Cormanus. I certainly cannot associate first-hand the challenges of dust accumulation on the chain as you may routinely experience, however, I suspect our south-west U.S. Forum members can align better to those members in Australia.Cormanus_imp said:Mmm, for a guy who dislikes maintenance, it looks like a good idea. Thanks for the information.
I elected to mount externally, however, the alternative was in my under seat "storage" cubicle near the battery. But my cubicle was full of stuff and at the time I was unsure how well the Tutoro would perform, so I mounted it externally thinking I could easily remove it if I didn't like it. It has been in place for four years.The ferret_imp said:GO how about a close up pic of the unit mounted on your bike?
There is a small knob on the lower side that ranges between completely closed to completely open. I would guess there is about 4 to 5 rotations of range. The user's guide provides suggestions of drip rate. Using a magnet, I hold the plunger weight in the open position and count the drip rate per minute to the rear sprocket. I think in my case I have it set to two drips per minute, or about 2.5 turns (if I recall correctly) of the valve. The magnet is then removed. Your mileage will vary with your personal need, the type of lubricant you choose, the season, and the lubricant weight. I use a 10W40 weight. Tutoro has their recommendations.The ferret_imp said:and what determines the correct rate of drip?
GoldOxide_imp said:I elected to mount externally, however, the alternative was in my under seat "storage" cubicle near the battery. But my cubicle was full of stuff and at the time I was unsure how well the Tutoro would perform, so I mounted it externally thinking I could easily remove it if I didn't like it. It has been in place for four years.The ferret_imp said:GO how about a close up pic of the unit mounted on your bike?
And the close-up ...
The drip tube basically runs down, then along the swingarm, and then lays on the lower hemisphere of the rear sprocket just above the passing chain links.
Hey PB: I have commented on this in the past on the Forum. I just didn't supply images ... I don't think? We are all here at the Forum to help make life easier (and sometimes cheaper) for everybody. If you want to wish your chain maintenance away (or reduced significantly), something like this could be it.peterbaron_imp said:GoldOxide_imp said:I elected to mount externally, however, the alternative was in my under seat "storage" cubicle near the battery. But my cubicle was full of stuff and at the time I was unsure how well the Tutoro would perform, so I mounted it externally thinking I could easily remove it if I didn't like it. It has been in place for four years.The ferret_imp said:GO how about a close up pic of the unit mounted on your bike?
I like this wise and neat set up you chose. Is this reservoir bolted directly to the plastic chain guard?
I love doing my own maintenance, but I may copy your solution due to set up above, unless your copy right applies?
cool keep us up to date on the project pbpeterbaron_imp said:If I go ahead with this project - love manual maintenance, I will incorporate the container into plastic chain guard with reenforcement and mini tube, we'll see..
Good question Cormanus.Cormanus_imp said:Does the tube get bounced around by the movement of the chain? Is there a risk it could be damaged? Or is that part of the deal?
