pekingduck
Road warrior
What I said previously about mounting the speed sensor at the sprocket was a bad idea because the alignment will change when the chain is adjusted. It looks like the magnetic sensor comes with a bolt with a magnet in it's head to replace a rotor bolt. If that bolt is the wrong diameter you can buy different size bolts with magnets from Trail Tech.
hy:
